Home > 998cc > anyone have any infor on aT04E Turbo? Help!
minimongrel
Member #: 10419
Has anyone run a T04E turbo on a 998/1275, i stumbled across it in the classifieds and i figured it should work considering it came off a 800cc snowmobile(im a canuck). I couldent find a map for it or any information except its good for about 400bhp (obviously not runing on a mini). please let me know if anyone knows anything about this.
thanks
Mini Mongrel.
Forum Noob
jakejakejake1
Member #: 10010
Northants
From a quick google it seems to be associated a lot with a T3, possibly a common hybrid or something. So by the sounds of it its quite a big turbo, not really suited to a mini unless going for mega power.
minimongrel
Member #: 10419
I wasn’t looking for mega boost or anything crazy just a little more of a punch when needed, but I guess it’s time to up rate the clutch and buckle up if that’s the case I hope it spools ok. come winter again I will probably post some build pics.
probably wont spool untill about 5 k,
the snowmobile it was off probably had a power band between 5 and 10k
KLAS
Member #: 2380
Hamburg, Germany
http://turbocharged.com/catalog/compmaps/fig11.html
but you nee to know what trim it has
400bhp on a 2-3L car lol, i just sold one and would not consider it in a mini whey too big
minimongrel
Member #: 10419
Well then lets just go ahead and open a can of worms here and ask the biggest open ended question, what turbo should i use, its going to be a side mount with intercooler i only really want run under 10psi anything more and i would have to build an engine to support this and i don't have the time nor capital to do so. so in that light a cheap turbo is needed, something that is easy to find in the americas would be prefered.
GT17 from the saab 95 is ideal,
as above
minimongrel
Member #: 10419
any sugestions on some store bought items, the only 9-5 turbo is going to be on a 9-5 and well i don't need another car!
bakker110
Member #: 9367
Derby
eBay or breakers.
minimongrel
Member #: 10419
so i found out somthing that will hopefully be useful and maybe will help, the Ford 3.5L v6 uses two GT15 turbo chargers could this possibly work, if to these are a dime a dozen in the oilsands region of canada.
the 15 may be viable as your keeping to lowish boost, do you know what particular type eg GT1549.
this is wothr having a play with to estimate your options
http://www.motorgeek.com/?fullpage=true&page=flowcalc
Edited by Joe C on 2nd May, 2013.
minimongrel
Member #: 10419
nice link i think for the time being i will try to find a busted up ford ecoboost. or a gt17
