Home > Show Us Yours! > Mini cabriolet turbo - ground up resto!
WRLondon
Member #: 8636
Surrey
Right have another thread where I introduced myself a few years back but yeah
As its @ bare shell stage thought it would be good to start a new chapter *happy*
Almost finished the in-out respray;
And now the new bits are almost ready to bolt on!
Update soon :)
Reading up on RTS Clutches
WRLondon
Member #: 8636
Surrey
doors & boot painted :)
Is that satin or gloss white? Satin looks good! :)
So what is the plan?
WRLondon
Member #: 8636
Surrey
its satin atm as it needs flatting back and polishing haha
plan is
1293 turbo
Omega forged pistons,
MED T3 Cam
t3 turbo & adjustable wastegate 10-15psi
radtec radiator
etc.
got new subframes painted and built up
hi-lows, lowered coil spring conversion
new gaz adjustable shocks
basically everything new :)
and white (REAL) leather interior
pics will speak a 1000 words
and i could probably type 2000 about the spec!
White car with white interior? Well pimp.
WRLondon
Member #: 8636
Surrey
Red doorcards and roof though
The seats are abit tarty but look the nads haha!
WRLondon
Member #: 8636
Surrey
Lacquered but came up with some orange peel
Wet-sanded looking abit better
Takes bloody ages!
Still needs tcut'ing & polishing
Engine is almost built but no pics yet!
Edited by WRLondon on 29th Apr, 2013.
welshdan
Member #: 1111
s wales
what are you flattening that back with? I go straight in at 800-1000 grit went and dry on mine. working back through 1500, 2000, 2500 grit to take the scratches out. then machine polish with g3 cutting compound, followed by g10, then polish, then wax. I use plenty of water, also a bit of washing up liquid in with the wet and dry. its very time consuming but worth it in the end.
WRLondon
Member #: 8636
Surrey
1200 - 1500 - 2000
12 was BOGOF haha
havent used g3, just have a lot of t-cut about but not got round to that yet
engine's built up now though!
is there a massive positive reason to spend £15 on g3?
think ive got some auto glym cutting compound too
Colour restorer?
APS
Member #: 10369
Pickering, North Yorkshire
If you buy and use g3, you need to use a mop, or it is very possible to tram line with your fingers.
If you haven't got a mop, use g6 on a rag etc, then g10 and then I personally use 3m hand glaze after that, but people will have other opinions about wax.
www.apsbikes.co.uk
WRLondon
Member #: 8636
Surrey
Getting there...
New loom, new front suspension set up
And also got the driveshafts & hubs recon'd
Edited by WRLondon on 3rd May, 2013.
Good effort mate. Looks like you're doing a nice job. *smiley*
WRLondon
Member #: 8636
Surrey
Turbo'd mini cab *happy*
Thanks phil *happy*
Edited by WRLondon on 4th May, 2013.
Looks like you got a fair bit done.
As for the cutting back etc, i generally work on paper graded depnding on how much needs to be cut back, finishing wth 2500 then use g3 on the mop. To be honest, if you've not got a mop, i'd try and get one for the job, buy or borrow. It makes a huge differance
WRLondon
Member #: 8636
Surrey
I've had one of these for years, will that do the job?
http://www.halfords.com/webapp/wcs/stores/...65640&langId=-1
Doubt it. I struggled to get a decent polish using one years ago so doubt very much it would be quick enough for a cutting compound
WRLondon
Member #: 8636
Surrey
Will see if I can borrow one
If I'm buying what's a gd'un?
Should go check out detailing world I guess!
Any wayyy filling the engine bay nicely
Not a lot of room though >.<
welshdan
Member #: 1111
s wales
I would stop putting it together and sort the paint first. G3 on a mop goes everywhere so would get that out of the way first!!
WRLondon
Member #: 8636
Surrey
I need to get it mot'd this week >.<
Will take it off and give it a mop over the weekend
What's a good reasonably priced mop?
welshdan
Member #: 1111
s wales
Got mine from frost a while ago, wasnt a bad price. You can get different corse mops for it, ie a g3 one for cutting, a softer grey one for g10/ polish. Make sure you use plenty of water as you can burn the paint if it goes dry, especially with the g3/ corse mop
WRLondon
Member #: 8636
Surrey
No pics atm but pretty much mechanically done
Will be starting for the first time Toni and have it completed by the weekend *happy*
your not hanging about
WRLondon
Member #: 8636
Surrey
It's getting there :)
Will post a vid of its first start this evening
Good or bad :/ haha!
Edit;
Fuel pipe split! Buying one Tomo :)
Edited by WRLondon on 15th May, 2013.
WRLondon
Member #: 8636
Surrey
Carpet fitted and cut to size just needs glueing
Dash all hooked up
Quick shot of the boot with fuel pump
Will get a shot of the rear subby when it's time to bleed the brakes *happy*
Still got to fit;
Front brake hoses
Roof, glass, seats, door stuff & exhaust
Bleed the hydraulics
But feeling like the home stretch *wink*
Should be done in the next few days!
Edited by WRLondon on 16th May, 2013.
