Home > Wanted > Mini metro turbo engine to be finished need parts!
Jake0201
Member #: 10391
Nuneaton, midlands
Hi I have recently found that I have a metro turbo engine in a classic mini that I have purchased.
Basically I need help because I have suddenly felt the urge to turbo it now that I know the engine originally was turbo'd!! I have the hif44 carburettor already I think (I may be wrong) but I need the turbo T2 garret I have been told are better? Then the adapted manifold, plenum chamber, fuel pump and an intercooler/new radiator?
I also need two mk3 doors?
Any help on this would be great and if I need anything else or if there is anything difference to fitting the engine, bearing in mind I have just removed it as it is and it already had the carb on it..
I have this manifold on it currently, would that work?
Any help would be great!!!
Thanks!
Kean
Member #: 341
aka T2clubby
South Staffs
Have a look in the beginners section on here, and use the search button, there is tonnes of info about the basics on here.
Also have a look on Phils site www.turbo-mini.com as it has a great introduction to turbocharging your mini.
jakejakejake1
Member #: 10010
Northants
Hi mate, I would get hold of 'tonyl3' on here, he is also based in nuneaton and has lots of parts for sale and may be able to help out.
Mr Joshua
Member #: 1954
Luton Bedfordshire
The original turbo inlet manifold has a deep swan neck to lift the carb clear of the turbo if you use a t3 that manifold does not look to give enough clearance I do not know how much clearance you need with a t2
Own the day
Jake0201
Member #: 10391
Nuneaton, midlands
Thanks for your help guys, finally got in my head what I need just need to find the stuff now! If you hear of a mirage manifold and t2 or a complete t3 turbo with turbo manifold could you PM me! Thanks
kappa
Member #: 9854
Hounslow, Middlesex
Hi Jake there is a guy selling a turbo set up on the mini forum:
http://www.theminiforum.co.uk/forums/topic...o-turbo-set-up/
