Home > Help Needed / General Tech Chat > Crank sensor wiring
tadge44
Member #: 2500
Buckinghamshire
I., sorting out the Megajolt for the van and am using a SC bracket and trigger wheel with the Magneti Marelli crank sensor, which fits the bracket, as intended.
Its the same sensor is used by Cosworths (and others) and came with a two pin female plug. I need to extend the lead and cut off the the plug as I dont have the corresponding male part anyway.
There is a blue wire and a black wire - which is the positive one - anyone please ?
wng691s clubby
Member #: 9252
Cleethorpes
mine has the symbols on the plug case if that helps
Done now needs redoing lol
Male half of the plug is easy to get, personally I would not disturb the OE wiring on the sensor, then if you ever need to swap the sensor it's an easy unplug-plug in job, no wiring mods needed.
tadge44
Member #: 2500
Buckinghamshire
Even with the male plug I would need to know which was the positive connection though.
David,
I agree with Tom, don't cut it...
But the colours do not match my Cossie wiring diagram anyway, the crank sensor on the Magneti/Marelli ones (before Ford did their own) should be brown and green.
But I've had problems with Ford's manuals just recently as Tom will confirm :)
Also, the Magneti/Marelli sensor reads a four tooth wheel (on the Cossie), not a 36 tooth so may not be happy with a 36. (the Cossie cable is NOT screened because of the lower frequency).
Maybe yours is from a later one but I thought when Ford dumped the Magneti/Marelli system, they dumped everything in favour of their own.
But again, I could be wrong.
Are you sure it's a Cossie sensor you have, Magneti/Marelli did lots of stuff for other cars ???
EDIT - typos
Edited by Rod S on 28th Mar, 2013.
Pin one is usualy posative
The Cosworth type Marelli sensor has been tested with a 36-1 wheel to nearly 9500rpm on the DON so no worries on that score!
I can't remember exactly from memory, but what you need is a Junior-timer male socket, now I think its a 2-pin one, BUT its not unknown for them to use a 3 pin housing (physically wider) with just the two pin recepticles in use.
It's the 2 pin one. I made an extension up for mine recently. I just bought a male and female junior timer connector and made a straight extension. Was a PITA to put together, but should do the job nicely.
The ford plug seems to fit my new sensor...
nala56
Member #: 9661
Sheffield South Yorkshire GB.
As above..
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Andy put me on to my new sensor and as I say it fits my ford plug, but he says I will have to reverse the wires so will do it at the Enis end where I have snap connectors, will I be ok to try without any damage to find the right polarity? Anyone know please.. Alan
Main Build
Upgrade to Turbo
Tom, I'm sure you are right but, like me, I'm sure you use an adaptive ECU.
EDIS (which MJ uses to read the crank signal) is seriously old.....
So "may" not be happy with a VR sensor intended for different speeds.
I have no evidence one way or the other but I would tend to err on the side of safety and use the VR sensor intended for EDIS on an MJ install rather than something that wasn't used on EDIS.
Just my opinion....
On my sensor there is a '+' on the plug. this equates to pin 2 on the female socket.
They are minitimer 2-pin, like these http://www.efi-parts.co.uk/index.php?categoryID=84
tadge44
Member #: 2500
Buckinghamshire
This SEN8D sensor is the one supplied by SC to go with their bracket and trigger wheel for An A series MJ installation, so I guess it will work.
As nala56 says, will it do any harm to try connecting it either way just to see which way works ?
Right I wired mine yesterday and I can confirm its back to front.
For the car to fire I had to put the negative from the Edis unit to the plus shown on the sensor plug. Then brum brum!
tadge44
Member #: 2500
Buckinghamshire
So no harm done if its wired up wrong in the first place ?.
Nope as it tried it the other way first
lee.pb
Member #: 9199
Lancashire
so is the positive, the one closes to the mounting lug or vise versa *oh well*
just started wiring loom for MJ today and was one of the questions i wanted to ask.
could someone confirm the picture below is correct for the coil pack connections.
spark output A to pin 10 on Edis4
spark output B to pin 12 on Edis4
sorry for the hi-jack
nala56
Member #: 9661
The top wire in your photo goes to pin12, middle wire goes to 12v suply, the bottom wire goes to pin 10.. Alan
Main Build
Upgrade to Turbo
lee.pb
Member #: 9199
Lancashire
cheers alan, i suppose if you got it wrong you could just swap the pug leads over. *surprised*
still need help with vr sensor gents, i'll check the colours and post *happy*
lee.pb
Member #: 9199
Lancashire
lee.pb
Member #: 9199
Lancashire
wires coming off the VR sensor:
Brown with red tracer.
White with red tracer.
