Home > 998cc > Pistons to use with 12g295 head Hypatec?
gilled
Member #: 9973
I have a standard 12g295 head i am going to run a gt1549 turbo.
Is it best to go for dished or flat top hypatec pistons?
jakejakejake1
Member #: 10010
Northants
It depends on the chamber size, and what compression ratio and boost etc you are going to run.
assuming a chamber size of 28cc, then the flat tops give a little over 9:1 CR. The 6cc dish takes this down to 8.5.
both CRs are fine for boost, just depends what you want.
gilled
Member #: 9973
Thanks for the reply, I am aiming for around 130 hp with the potential for more. So do you think the dished pistons will be a better choice in the long run?
for 130 bhp you'll need 12 to 15 psi. So I'd play it safe with the lowe CR and dished pistons.
gilled
Member #: 9973
Are there any other pistons that will do the same job that are avaliable over here, and has anyone used the dished Hypatec i have read that they are pretty good?
I use the Aus Mini dished hypertecs, they are fine. Not a perfect turbo piston, but good enough.
MED sell the forged Omegas with a 5.7cc dish. But these are pricy. good for as much power as you want though.
gilled
Member #: 9973
I am now around owner of some hypertec pistons.
