Page: |
Home > Technical Chat > GT1752 exhaust flange | |||||||
1434 Posts Member #: 8466 Post Whore Mansfield |
10th Mar, 2013 at 08:44:18pm
Does anybody know where to get a stainless tapered flange and triangle retaining plate for the GT1752. I know you can buy the Saab downpipe and modify, but not in stainless. I've seen a few flanges on eBay, but I'm not sure on the taper angle etc. Class C 3rd Place Avon 2011 14.18 @101mph |
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
11th Mar, 2013 at 10:30:38am
Can you get them from mirage? The turbo build has finally started |
673 Posts Member #: 1395 Post Whore chepstow |
8th Aug, 2014 at 05:25:29pm
Anyone know the answer to this? I'm after a stainless flange for the gt17 downpipe too |
283 Posts Member #: 8215 Senior Member Rayleigh |
24th Sep, 2014 at 04:42:20pm
I made a disc with the correct PCD and center hole then put a 45deg taper on with a lathe. And welded my downpipe to te flange so it's fixed. My first downpipe was a modified Saab one which was easy for positioning but kept coming loose. Edited by Custard on 24th Sep, 2014. Dave the Cake |
336 Posts Member #: 9941 Senior Member Derby |
24th Sep, 2014 at 05:04:25pm
In tutbury there's a company called jr fabrications they have a nice little workshop and have all the machines for mandrel bending, or flaring the ends of tubes basically can do everything for custom exhausts not sure about the flange tho I got them to put the correct face on a 2 1/4piece of pipe for attaching to the turbo then got the turbo flange off a saab and lathed the inside out so It was big enough Edited by jamiestevenbell on 24th Sep, 2014. |
24th Sep, 2014 at 05:05:48pm
Sorry I got mixed up they can make the tapered flange not the triangle retaining plate |
24th Sep, 2014 at 05:06:47pm
539 Posts Member #: 6807 Post Whore York |
24th Sep, 2014 at 05:20:59pm
I have currently sent out for some quotes on getting the triangular plates laser cut in 5mm 304 stainless. I'll report back once I get quotes as I'll be getting 10 of them cut |
24th Sep, 2014 at 05:30:18pm
The taper angle is 51 deg. I'll also be machining the tapered collar for my project so I can machine more for people if required? Cost dependant obviously |
24th Sep, 2014 at 06:51:38pm
Are you keeping the same standard Saab set up? Or having it fixed. How did you measure the 51deg angle?
Dave the Cake |
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
24th Sep, 2014 at 07:20:47pm
Matty had some made. It may be worth asking if he has any spare.
In the 13's at last!.. Just |
11046 Posts Member #: 965 Post Whore Preston On The Brook |
24th Sep, 2014 at 10:14:23pm
Why go to the expense of making the flange in 304 stainless when the turbine housing is bare cast iron? On 26th Oct, 2004 TurboDave16v said:
25th Sep, 2014 at 07:16:04am
I've said this before in another thread. The flange/mounting plate and flared end are available on ebay, they're standard bits(not SAAB standard, just general parts).
Edited by wil_h on 25th Sep, 2014. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
384 Posts Member #: 4215 Senior Member |
21st Jun, 2016 at 11:59:19pm
bringing this back from the grave
Page: |
