Page: |
Home > Companies to Avoid > Med light Verto flywheel st2 kit problems. | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
18th Feb, 2013 at 11:02:04am
so i have had great dealing with this company, still hold them in high regards.
Edited by NickG on 18th Feb, 2013. |
313 Posts Member #: 9367 Senior Member Derby |
18th Feb, 2013 at 11:48:09am
Mine works fine. |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
18th Feb, 2013 at 12:38:18pm
Sales of goods act of 1979!
18th Feb, 2013 at 12:56:28pm
mine fits fine,
18th Feb, 2013 at 08:10:48pm
Yeah the one I have whe measured against
![]() 2094 Posts Member #: 9894 Post Whore Dorking |
18th Feb, 2013 at 08:51:01pm
I have one of these. Yet to try it though! |
18th Feb, 2013 at 09:53:57pm
Instead of binning it, can't you fit another ring gear and fit it in the correct place?
18th Feb, 2013 at 11:46:00pm
I've got one too. No such problems.
In the 13's at last!.. Just |
20th Feb, 2013 at 12:49:04pm
going to make one up in alloy instead.
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
20th Feb, 2013 at 01:00:08pm
MED told me they get their ring gears from Asia, so it would be a factory in Asia then. Edited by dazibee on 20th Feb, 2013. |
21st Feb, 2013 at 11:10:21am
yeah they told me they only use factory rover ring gears.... as i assumed.. hate people that lie to your face.
21st Feb, 2013 at 02:08:28pm
Backing plate?
21st Feb, 2013 at 07:13:42pm
The Verto flywheel has a Verto ring gear. What type of starters are you using? I'd have thought that there are few pre engaged starters in Aus, and in the main, they would be inertia?.......
22nd Feb, 2013 at 11:49:25am
im using a high torque starter.
22nd Feb, 2013 at 12:12:37pm
Tried it with a standard starter?
24th Feb, 2013 at 12:04:56pm
that was the first thing i did. no good.. tried it with a high torque & every pinion they use with it for every ring gear & still no good. |
756 Posts Member #: 1355 Post Whore Leicester |
28th Mar, 2013 at 08:32:24pm
i have this problem too. i spacer my starter out with soneone washers then its fine.
Page: |
