Page: |
Home > Wanted > Spi banjo bolt | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
17th Feb, 2013 at 05:41:13pm
Need an spi banjo bolt and pipe to oil filter housing.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
18th Feb, 2013 at 07:17:01pm
??...... There is no Banjo bolt on the SPi block..............
18th Feb, 2013 at 07:39:35pm
On 18th Feb, 2013 Sprocket said:
??...... There is no Banjo bolt on the SPi block.............. You need the late A+ pipe. Cheers sprocket, found some pictures on google. There prone to leaking and since I've got the early type filter head going to order a braided hose. Thanks again. What the mind can conceive the mini can achieve
Page: |
