Home > Track, Drag & Race > Fitting a ARB to mini for circuit/hillclimbs
boostjunkie
Member #: 9117
Northampton
Hi all basically does anyone have any experience with anti roll bars on minis? I'd like to fit one but wonder..... Would it work better across the rear wheels or front wheels?
boostjunkie
Member #: 9117
Northampton
sorry mods posted in the wrong section could it be moved to "Help Needed / General Tech Chat"
thanks
I run front and rear, some run just rear.
the bug advantage is that it makes the car tuneable for under/oversteer. If you're going to run a front, then an LSD is useful.
boostjunkie
Member #: 9117
Northampton
Thanks for the reply wil not sure to go for front or rear as I only have one at moment, double throttle spring how's the best way of fitting them to the std su carb any Piccys *wink*
If only using one ARB, a rear one is the one to fit.
All HIF carbs have two springs as standard.
boostjunkie
Member #: 9117
Northampton
Sounds good, cheers Wil
