Home > Wanted > Parts needed for my build
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I am basically looking for parts, I maybe calling the the wrong part, so sorry if i do.
Basically I have a metro turbo engine & gearbox and need the Speedometer Pinion either for a 3.1 or 3.2 final drive and Speedometer plain bush, these are the names in the Haynes Manual.
I am also looking for a 4 pin diff and I am also looking for 2 x Idler gear conversion roller A+ to pre A+ for my dropgears set.
Anyone have any of these parts please give me a shout.
Bobby
Mike-998
Member #: 9774
Buckinghamshire
You'll need to work out the speedo drives you need using the calculator on the guess-works website, it will depend on your wheel size, type of speedo, gear set ratios and drop gears. Once you know the ratio (mine for a 3.1 was a 7/17) i'm sure someone will be able to help.
welshdan
Member #: 1111
s wales
theres a calculator on the 'guessworks' website.
i will have a barely used tranx four pin diff for sale within the next month i would hope. it has only covered a few hundred road miles, if that, so just whilst the engine was running in.
kappa
Member #: 9854
Hounslow, Middlesex
You have pm
