Page: |
Home > How To > Custom Downpipe | |||||||
323 Posts Member #: 41 Senior Member |
23rd Dec, 2003 at 06:05:05pm
After reading about peoples problems (and the problems i have had) with trying to fit the downpipe properly i decided to hack mine about and make a custom one. i onyl think this problem occurs when people havnt used a later type cooper subframe or make new mounting holes to bring the engine forward (i have not done either) but my downpipe should also stop the problems associated with movement within the exhaust system, see pics A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
21st Feb, 2004 at 06:53:47pm
That looks good, As that nuckle joint is a real pain, as it hits on the rolling road to! Best 1/4 mile 13.2 seconds @116 mph
21st Feb, 2004 at 08:49:10pm
You can also use the std metro turbo item... its got double springs, so sits strighter!
AlexF |
21st Feb, 2004 at 09:20:56pm
only prob with that alex is that is slightly smaller isnt it? but yeah a std metro is a good alterntaive. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
22nd Feb, 2004 at 10:53:20am
Not sure.. I've only got two that are both 2nd hand... so nothing to compair to.
AlexF |
22nd Feb, 2004 at 03:56:59pm
yeah when i bought my engine it came with the metro downpipe and im sure it had 2 springs and it was a smaller diameter. i have a pic of it somehwere, will have a look for it A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
82 Posts Member #: 78 Advanced Member milton keynes |
23rd Feb, 2004 at 07:21:51pm
My downpipe seems to hang very low down its very close to the ground. 1310 turbo did you make it slightly shorter? fed up with it hitting everything lol |
24th Feb, 2004 at 07:18:04pm
no its pretty much to the same dimensions as the maniflow turbo downpipe. mine before i cut it up didnt hang low to the ground A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
15th Mar, 2004 at 09:02:04pm
wil have to try that did you take alot off? |
321 Posts Member #: 557 Senior Member Ireland |
25th Jul, 2005 at 10:18:35am
Any chance of reposting those pictures? |
Page: |
