Home > 998cc > 998 with 69mm bore
stealth05
Member #: 10216
west yorkshire
Hi i am dav and been into minis for decades ,been advised to come over here and get some advice , i have taken in px a 998 mini engine , this is no ordinary 998 ,got it off an old boy who used to race mini stox it is bored out to 69mm offset with fiesta hcs flat top pistons and running a 1275 cam ,was wandering what kind of cc the engine would be classed as ,comes with standard 998 head as this is all he could run in the class he was in ,says it would fly if pocketed and 12g940 big valve head was fitted ,never heard of this kind of bore to 998 before so just wandered what your opinion on this engine would be .I am currently building a standard mg metro na engine ,would this 998 out perform the mg engine with the right head ect?
cheers dav
Edited by stealth05 on 23rd Dec, 2012.
mattsmadmini
Member #: 9965
Sydney, Australia!
69mm offset... thats getting mighty thin between the walls! im not too good with the conversion or figuring out cc, i can tell you a 68mm offset (Imp Pistons, or similar 0.134 thou OB) is 1220cc, i wouldnt think a small bore block could go much further!
Ive had a drive of a 1220cc imp pistoned small bore, sooooooo much torque! it had a 12g940 and a 45 weber, pulled out an easy 67hp at the wheels last dyno day... the engine is great! i would consider building one for an NA application, built right would be a fantastic daily motor.
Ta,
Matt
Edited by mattsmadmini on 23rd Dec, 2012.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
stealth05
Member #: 10216
west yorkshire
thanks mate ,def 69mm i have measured it with a vernier gauge ,he mentioned oil galleries have been sleeved or something ,running race diff of some form and heavy duty clutch ,but would have to pull it apart to find out ?
Well it won't be as big as a 1275, so ultimately it won't make as much power.
It's a bit of an oddball really, would have been a good engine in the class it was running in, no doubt. But as you're not constrained by rules, you'll make more power with a 1380 etc.
Unless you want something unusual, it has no real advantage. Personally, I like the idea.
Chalkie
Member #: 9764
Northamptonshire.
This engines forsale on TMF for like £250 not a fan of the offset at 69mm bit mad maybe with a 940 head it out run a standard 1275
stealth05
Member #: 10216
west yorkshire
yes i have it for sale up on tmf for £180 now but i have just purchased a 12g202 head so thinking of building it and sticking it in my mini till 1275 is finished to see what it goes like .
dav
Edited by stealth05 on 24th Dec, 2012.
stealth05
Member #: 10216
west yorkshire
cheers i have run a 1380 in the past but like the way the 998 engine revs ,so thought this would be a little screamer *surprised*
Large and small bore engine really rev the same. But you need a better head on the 1275. It's pretty easy to get enough breathing to make a 998 rev. Problem you'll have with this engine is a 202 will strangle it.
stealth05
Member #: 10216
west yorkshire
cheers so will require 12g940 to breath then ?
Yes, or an SC 7-port, or an 8 valve k head would be great.
Chalkie
Member #: 9764
Northamptonshire.
I have a spare 940 head will just drop stright on if you want to make an offer
Ben H
Member #: 184
Melton Mowbray, Pie Country
Will a 940 drop straight on? I wonder with that bore will it need pockets? Also I wonder what the compression ratio would be?
http://www.twin-turbo.co.uk
stealth05
Member #: 10216
west yorkshire
i know mate these are all questions i need answers to before i spend anymore on it ,was advised to get 202 head but now its going to strangle it *surprised*
Alex
Member #: 1851
Woolavington, Zummerzet
I'd love to see the pistons & rods and know the deck height.
mattsmadmini
Member #: 9965
Sydney, Australia!
ditto...
a 940 on this would be beautiful... a twinky head would be pure porn though *evil*
Alex
Member #: 1851
I've got a full-race 12G295 with 'S' valves in it - a bore this size would be magic...
stealth05
Member #: 10216
west yorkshire
cheers not sure what route to go with this now
pull it apart ?
sell it ?
buy a head and run it ? (but i have now got the mg 1275 engine)
wng691s clubby
Member #: 9252
Cleethorpes
go 1275 more power to start off with and more to gain if wanted
Done now needs redoing lol
Alex
Member #: 1851
Stick a decent head on it and get it running - if you decide you don't like it and want something different it will always be worth more as a running engine.
Having said that, we'd all love to see the insides before you do...
Chalkie
Member #: 9764
Northamptonshire.
940 head should drop on depending on the offset small valve
and a 202 head is rubbish smaller ports that later 998 head (well mine is)
Wrong!
stealth05
Member #: 10216
west yorkshire
think this 202 must have been messed with then as the ports are mahuuuusive
stealth05
Member #: 10216
west yorkshire
pulled it apart and the engineering work is amazing
