Home > For Sale > Mini 8v Twin Kam turbo project
advantage998
Member #: 1840
Kings Lynn, Norfolk
Due to work/time commitments i've not dedicated as much effort to the mini as it deserves. I feel ashamed to leave it sitting gathering dust and could do with putting the money towards a deposit on a house rather than under a dust sheet, so i've decided to put it up for sale.
More pics: http://s21.beta.photobucket.com/user/advan...ni%20For%20Sale
Engine
1293cc Mini Twin Cam Engine
9.1:1 Compression ratio
BMW 8V fully refurbished head
Cam cover fitted with oil filler neck, shot blasted and painted
Modified fuel rail fitted with Aeroquip fittings
Brand new Bosch EV14 injectors (320cc/min)
Specialist components conversion kit
Dry decked – Machining by Specialist Components
Ferriday Engineering 1.6mm FSR Head gasket
Tuffrided lightened crank
Omega Forged Pistons
Lightened, balance and stress relieved rods
BMW under crown oil jets
Oil galleries machined for removable plugs
Centre main strap.
Arp Head studs, main bolts, rod bolts
DSN Classics Billet oil filter housing with turbo oil feed
Powerlite high torque starter motor
Specialist Components trigger wheel and sensor
Romac crank damper
SH Engineering 32mm water pump outlet
Dynamically balance crank, flywheel/clutch and crank pulley
Nearly new Garrett GT2056 turbo
Semi-completed inlet plenum
Brand new Jenvy throttle body
Gearbox
Quaife 2.877,1.827,1.329,1:1 Gearset
Quaife ATB Differential
Rebuilt with all new bearings, layshaft, bulk rings, gaskets
New Pot Joints
Minispares Evolution straight cut drop gears
Grey Diaphragm
AP Racing Road/Rally performance clutch plate
Minispares ultralight flywheel and backplate
New slave cylinder, arm, push rod, release bearing shaft and bearing
Vented clutch cover
ECU
Emerald K3 ECU
Wiring loom 90% completed all require connectors supplied
Brand new boost control solenoid
Brand new coil pack
Brand new Magneti Marelli 3 bar map sensor
Brand new VW EGT sensor
Body
Rollcentre weld in multipoint roll cage
Rust free
Shotblasted
Tubbed rear arches
Flat boot floor
Rear valance removed
Fuel neck hole deleted
Fibreglass roof skin
Fibreglass boot lid
Fibreglass 2 piece front end
Lightened steel door frames with aluminium skins
Polycarbonate windows
Single wiper arm conversion
Fire sealed rear bulkhead
Full width miglia style bulkhead box
Turbo bulkhead box
Aeroquip fuel hoses
Webber alpha adjustable fuel pressure regulator
Goodridge solid fuel hose inside cabin
Aluminium fuel tank
Fire/electric cut off cables
Lightened door handles
Glass windscreen
Suspension
Boot mounted rear anti-roll bar
Lightened, reinforced, shot blasted and paint front subframe
Powder coated arms, hubs, shafts etc
Minispares rose jointed adjustable bottom arms and tie bars
All new bearings, ball joints, rubber boots, seals etc
Solid custom subframe mounts to allow car to run lower
13” x 7” Minilight alloys fitted with Yokohama slicks
Brand new wheel nuts
Brakes
Minisport 7.9” 4 pot callipers and vented discs
Braided hoses throughout
Willwood lever type bias valve
Girling master cylinders with remote reservoirs
Mini-fin rear drums
New brake cylinders
DSN classics alloy handbrake quadrants
Re-located handbrake lever and new custom cable
Miscellaneous New Parts
Cinquecento radiator with temperature sender
7” cooling fan
Meziere water pump
AEM AFR gauge
Alloy catch tank
Alloy header tank
Longacre wide angle mirror
Front indicators with both amber and clear lenses
Acewell digi dash
TRS 6 point 3” harness
Sytec motorsport fuel pump and filter
Powervamp 25 sealed battery
Maniflow centre exit exhaust
Looking for offers around £8000, as there is over £15000 invested in this car
dev 11
Member #: 9393
stoke on trent
Good luck with the sale. Looks a solid base for a project, thought about splitting?
mw3
Member #: 9590
Derby
If you split it is be interested in the doors
Matt W
On 14th Mar, 2012 mw3 said:
Good luck with the sale, wishing i didnt just put a deposit down on a house *frown*
out of curiosity were you going to use the std cams on the 8v or custom profile?
Lots of nice bits on this one.
adcyork
Member #: 6807
York
If you decide to split this then can i call dibs on the rear view mirror, fuel tank, starter motor, ATB and fuel pump and filter?
Although i do feel i'm jumping the gun, good luck with the sale!
kappa
Member #: 9854
Hounslow, Middlesex
If you decide to split, can I have dibs on the gearbox? but good luck with the sale though mate
I would maybe have the eng, at the right price.
Amp
Member #: 7856
If you did split i'd also be interested in the starter, and the harnesses
jamiestevenbell
Member #: 9941
Derby
I'd be interested in the 7.9 brakes and defiantly the quaife ATB.
dev 11
Member #: 9393
stoke on trent
Id be interested in the turbo an brake masters set up
Also dibs on the single wiper conversion if
You do split?
Edited by dev 11 on 24th Dec, 2012.
philc
Member #: 1346
bromsgrove
shame about the sale, but if you split also interested in the starter motor and ecu and loom and poly windows (doors only)
advantage998
Member #: 1840
Kings Lynn, Norfolk
Thanks for the interest, will keep you all posted should i decide to split it.
ianjobber87
Member #: 10132
would be interested in a few bits if you look to split and I'm only up the road!
cheers
Ian
Andy500
Member #: 2443
Cheshire
As above would certainly be untreated in a good few bits if splitting
Auto correct is the spawn of evil and everyone should turn it off, lol
Andy500
Member #: 2443
Cheshire
Ffs at least it can't correct that!
Andy500
Member #: 2443
Cheshire
advantage998
Member #: 1840
Kings Lynn, Norfolk
Back up for sale, still not had the time to finish.
Offers please...
I'm interested in a large part, or the whole power unit if you decide to split.
philc
Member #: 1346
bromsgrove
if you do consider splitting there are things I am still interested in other than the poly windows
