Home > Show Us Yours! > The intercooler gallery - post your pics here
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I am not sure if this is done and sorry if it in the wrong section, but this will be for all the forced induction guys and girls.
I am building my turbo engine and wanted to get some ideas, I have bought a intercooler, so just wanted to get some pics of intercoolers fitted in the engine bay or even on the front of the car.
Bobby
Here you go...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=312831
kappa
Member #: 9854
Hounslow, Middlesex
Thanks for that, that is a big help
charlieb150
Member #: 9931
brighton
this is mine i used a mr2 side mount intercooler and a unviersal pipe kit
Nick
Member #: 154
Midlands
2wd cossie intercooler in a clubby, 51mm piping in, 63mm piping out.
kappa
Member #: 9854
Hounslow, Middlesex
looks good, cheers guys
bennyy
Member #: 9037
Doncaster, yorkshire
Custom made by ah fabrication, hazPalmer now owns this.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
PEP
Member #: 1145
North Wales
http://i1087.photobucket.com/albums/j480/p...zpse53b3ff1.jpg
Craigie-B
Member #: 9468
Wootton Bassett
Benny what size piping did you use?
kappa
Member #: 9854
Hounslow, Middlesex
Nick this looks good, what rad is that your are using, and by cutting the central bar out for the front slam panel, is there enough support?
eden7842
Member #: 8852
leicestershire
bennyy
Member #: 9037
It's all 52mm or 2"
vegar
Member #: 189
Anyone running 4x4 cossie IC with the radiator on the normal position?
www.shag.no
kappa
Member #: 9854
Hounslow, Middlesex
Hi Eden7482
How are you going to be running your piping for the intercooler? As I have the same intercooler and was thinking where to position? Also where are you placing your rad?
On 15th Dec, 2012 eden7842 said:
eden7842
Member #: 8852
leicestershire
Have a ganders
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=413417
Mine
Pic wont up load -_-
Edited by Brett on 16th Dec, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
Looks really good mate, I am using the original front steel end, so need to work out how to do my piping for the intercooler
On 16th Dec, 2012 eden7842 said:
Have a ganders
Best thing to do mate, is place all the bits where you what them, then sit back and have a good look where you would like the pipes to run. When you have done that make some tubes out of loo rolls and card to mock it up, this will give you an idea of what to buy.
I hope ths helps
As there is no out of the box setup for a mini.
Simon.
Edited by madmk1 on 16th Dec, 2012.
An earlier photo but it's still pretty similar,
Clubman (flip front) conversion.
Rad is Metro Mk1 (but the later Fiat Cinq which is more like the Metro for thickness/height also fits) and intercooler is Mk3 Mondeo TDCi, about the same core size as a Cossie 4WD.
Width could be reduced a lot by cutting off the plastic ends and welding purpose made right angle headers (I have a second core cut ready for this) and this woud make the piping much shorter and able to fit within steel inner wings.
