Home > 998cc > 11 stud 998 turbo block
mw3
Member #: 9590
Derby
Has anyone done (is it possible) a 11 stud conversion on the 998 block, there doesnt appear to me to be a lot of material around either end of the block near the bores.
So when the studs are put in they seem very close to the end of the block and the bores.
In hindsight do i actually need to go 11 stud, would using 9 Arp bolts be sufficient
Matt W
On 14th Mar, 2012 mw3 said:
9-stud will do the job fine.
Although am pretty sure there is enough meat in there to get 11 studs in.
As John says... also torque the head to 55 ft pounds
All my mid power 998 turbos are 9 stud. all my high power 998 turbos are 11 stud.
There is plenty of meat, but I only torque to 50Nm rather than 68Nm for the rest.
Wil where did you get an 11 stud small bore gasket?
All the 11 stud engines use a 940 casting and hence largebore gasket.
Ahhh I see I did wonder, I was going to have it done to mine until I found out you can't get the gasket
Alex
Member #: 1851
Woolavington, Zummerzet
At the risk of being chastised heavily, why can't you just drill through the 998 gasket to make an 11-stud one ?
I would have thought it would have been better to make a punch, less chance of separating the layers of the gasket that way.
I don't think you can make the small bore head castings 11 stud.
Edited by wil_h on 4th Dec, 2012.
You cannot go 11 stud with a small bore head. If using a big bore head, you'll need the big bore gasket.
So, pointless... *wink*
Alex
Member #: 1851
Worth drilling through a scrap 998 head to find out ?
I have a few kicking around, including a scrap 12G295.
(Scrap that is until the prices they fetch make welding it up worthwhile.)
I've got a corner in the shed with such scrap as well *happy*
There's no point in drilling a small bore head to try. Look at it and you'll see why not.
