Home > A-Series EFI / Injection > Serious data logging.....
Since working out how to use the MAFs (a slightly earlier thread) I've had some new PCBs made up,
Bottom left is my IOx-OEM (had that built for a while) and top left / bottom right are the miniature hall switch boards for our traction control so ignore them too.
All the rest are for up to 13 channels of data.
partially assembled
Four pressure sensors and the main data connector back to one of Jean's IOx's or IOx-OEM's
The pressure sensors are the most space intensive using just 50x50 PCBs.
And the whole box,
It all actually goes in the bottom half but not until I cut slots/holes for the data/power connectors.
What we will have is,
4 pressure,
4 temperature (not shown yet)
4 EGT (only 2 shown), and,
1 MAF
All through sticking with the MS2 and understanding how it works with Jean's IOx (albeit we may have to slow the data rate down slightly when using an IOx project at the same time as an MS2 project but Graham and myself haven't found this to be an issue yet despite Jean's warnings).
All part of trying to get a "total" picture of BSFC and the other unknowns on the five port.
well done rod ,looks, and sounds ,good.
Looking good.
What pressure rating did you go for with the sensors Rod?
Just the basic 250kPa Freescale ones (same as a standard MS2/3) so 1.5bar boost maximum. (22.5psi for the non-metric :) )
There are a few others in the Freescale range - just swap the calibration in the ini file - but the 250kPa ones are the most common (and cheapest...)
Just wiring it all up at the moment.....
If you're thinking of logging Turbine Inlet pressure, then it may be worth considering going higher. You will hit the pressure limit at quite low boost and it can be very spikey.
Good point....
We were only considering the air/fuel side (which "should" give the total picture).
Adding exhaust pressures may finally explain why I still have a 0.5 - 1.0 AFR difference between my dual widebands pre-turbo (that I can tune to read the same) and the one after the turbo.
A nightmare to install though on the hardware side, more pipes.... although still enough software space on the IOx I/O.
Easy enough:
1/8" BSP tapping in manifold, compression fitting, length of pipe and a coil to get rid of the heat before slipping the rubber pipe over the end.
You don't need the coil if you can fit a long enough pipe in. That picture was on the Mig remote turbo and actually ran down the wok and finished near the clutch plunger.
Not sure of the maths of what you are seeking to establish, but if it considers VE then TIP is a major player.
Edited by Paul S on 29th Nov, 2012.
Graham T
Member #: 1106
Hungerford, Berks
Nice work Rod. Looking good.
What spacers will replace the toilet roll/ kitchen roll tube?
Paul, I'm begining to get to grips with alot of this now, but can you explain/ give some pointers on how TIP effects VE?
I've opted for only 3 Pressure sensors on the inlet side. Rods boards allow for 4, so I could install one more for TIP.
As the engine has yet to come back out of the shell for spraying, I could easily remove the turbo to add pipework.
I imagine this would need to be as close to the exhaust manifolds Turbo flange? Or could I perehaps take a feed from the centre cylinders AFR sample chamber? (though I think possibly not)
Edited by Graham T on 30th Nov, 2012.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
Good point....
in case its usefull info ,i have measured over 45 psi of turbine pressure in the past , i used a brake pipe fitting in the manifold ,then a simple copper brake pipe about 15 inches long with a rubber pipe on the end . you can then crimp the pipe a little if the signal is too occilatory .
re the afr readings rod , could that be an earth offset difference? i thought that with the method of gas extraction you and paul are using , there would be little pressure on the sensor pre turbo ?
did you link 5 and 6 on the te box ,with the internal shunt ,maybe take the shunt out and run 5 over to a common point for all boxes ?(just had a picture of a grandmother sucking eggs and looking at me in marked manner lol.)
Edited by robert on 30th Nov, 2012.
TIP is usually higher than boost (unless you use tuned length manifolds to get around it). That means that the cylinder can't get rid of all the exhaust gas on the exhaust stroke, then at valve overlap you do not achieve effective scavenging.
It's one of the biggest, if not the biggest, problem of acheiving high VE on a turbo engine. There are numerous power curves on here that show the torque curve dipping away before the head and cam have had a chance to get going. That is usually due to too small a turbine creating a high TIP.
However, thinking a bit more about the maths, if you want to bottom out BSFC and you are measuring air flow then you don't need TIP. The air flow measurement itself will tell you VE.
Edited by Paul S on 30th Nov, 2012.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
from what i understand this is impressive stuff.. grate work!
Starting with Robert...
On the basis of 45 psi - the next model up in the Freescale sensors of that case design is 15-700kPa (so 85psi(g)), a bit OTT and will be down on sensitivity because of it.
They make a 15-500kPa model but not in that case design - annoying....
Re the AFR offset, it won't be an earth issue on the TechEdges because, at the moment, I don't use the analogue outputs, just the digital straight to the display modules. I can't actually remember if I put the internal shunt on or not as, at the time, I had no intention of using the WBlin outputs, differential or otherwise...
But now that I've got all this spare data capacity you've certainly made me wonder whether I should hook the analogue up (with and without the shunt) and see what it says.
Certainly the sampling method we are all using, in principle, should ensure the LSUs aren't pressurised - that was of equal (perhaps greater) concern than their temperature limits to me. Tube sizes, angles, everything I could do to give confidence, but the only way to be sure would be to measure it....
The only thing that niggles me a bit is whether taking the "outer" sample from just one exhaust port whilst the "inner" is from a double port is causing a pressure effect despite the tube sizes I chose. I think Graham is the only one to have commoned the outers up but we have no significant data from that engine yet.
In reallity the issue is most likely me having two TechEdges and one Innovate - my plan always was to move over to 14point7 SLC-OEMs (as Jean's IOx supports the 14point7 digital data format and they are very cheap compared to the mainstream manufacturers) but there were certain "issues" last year over the way he handled two problems of his own making so that plan went on hold.....
Now Paul,
You had me worried for a minute.... using MAF was a key part of our plan.
But for the price of another sensor and a bit more pipe to read TIP, it may as well be added to the list.
The engine's going to be back out shortly to fit the TC sensors (could probably do it from underneath but there is a bit too much play in the pot joint to gearbox support sleeve/seal so I want to re-bush them).
I'm seeing over 5 Barg (70 psig) TIP on the simulation of the new 998Ti at just 0.8 Barg (12psig) boost. Mind you, I'm purposely keeping it spikey to make use of the troughs :)
So the 15-700kPa one doesn't seem a bad idea then.
I've got enough space (physical and data) for it.
