Home > Show Us Yours! > 1310 turbo City E
hazpalmer
Member #: 9038
Carlisle, Cumbria
Right iv been on here for a while lurking! Iv finally got all the bits needed for my project and should see some progress this weekend hopefully.
Heres the mini:
Its a 86 City E. Had it restored last winter i think!
Iv got bits scattered all over the house.
But the spec will be:
1310 10cc cast omegas
Centre main strap
balanced rotating assembly
Lightened verto flywheel
RTS clutch
Benross head
S/C gearbox with X pin diff
S/C drops
GT1752 turbo
megajolt
alloy intercooler
playmini exhuast
That's the basic jist of things, il get some more pictures and let them do the talking.
hazpalmer
Member #: 9038
Carlisle, Cumbria
Heres some more pictures:
mercenary62
Member #: 9937
looks good to me mate,bits all over the house rings a bell lol
give em hell
hazpalmer
Member #: 9038
Carlisle, Cumbria
iv got the engine in the hall way, and all sorts of other bits in my room. Can't move!
mercenary62
Member #: 9937
yep i know that feeling so does the memsab
give em hell
Looks good, you should be up and running by sunday then.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I like the two-tone paintwork, looks smart.
On 7th Nov, 2008 Nic said:
naeJ
m
hazpalmer
Member #: 9038
Carlisle, Cumbria
haha i wish! Got to put it all together, run extra fuel line. Mod downpipe, sort oil drain and feed, rebuild carb and sort out the extra gauges amongst other things.
hazpalmer
Member #: 9038
Carlisle, Cumbria
i copied it from a minimag feature car, that i saw when i was at school and said my mini would be like that.
madonminis
Member #: 9371
East Yorkshire
Best of luck harry. Thought the mini was smart last time I saw it. Will be better with the turbo.
hazpalmer
Member #: 9038
Carlisle, Cumbria
Cheers since you saw it iv had the front end resprayed and the roof as well. And i got my new bonnet fitted, so it just needs a engine to get it going!
hazpalmer
Member #: 9038
Carlisle, Cumbria
Not done much on this! My mate robs coming over on saturday to collect all my engine bits. That way we can piece it all together and get everything right before we drop it in!
In the mean while, i fitted my electric fan to my rad. And changed fly wheels too.
Clutch and fly wheel were out of the metro van, its a RTS. I changed the fly wheel over for a minispares lightened verto jobbie.
Original: 4.9kg
New: 4.2kg
hazpalmer
Member #: 9038
Carlisle, Cumbria
UPDATE!
Last sunday Rob and his Dad came over to collect the mini and take it to their garage.
Got all the engine bits bolted together, went together without any problems...
We dropped the engine in and trial fitted the turbo on the manifold. We were not happy with how close it was sitting. We tried rotating the house and looked at how to mount the actuator. In the end we took a grinder to the bulk head for a little extra clearance.
Once we were happy with how it was going to fit, we mounted the manifold to the engine ready to drop in.
Got it all dropped in and got the engine mounts in. And i had to make up a bracket for the actuator.
After today we got the alternator on, starter on, actuator bracket finished. We also got the carb and plenum on. Got the trigger wheel and sensor and bracket mounted.
All comments welcome as this is my first turbo build, and although Rob knows minis he hasnt done a turbo one before.
Harry
kappa
Member #: 9854
Hounslow, Middlesex
Looking good mate
Get a MPI manifold Gasket as they are better.
Have you seam welded the bulkhead box?
