Home > FAQ / Knowledge > any ideas on which crank this is?
snail
Member #: 567
hi i have a crank with the following number stamped into it 957 88319 EC6 it has step in the crank nose which would indicate its 1275 but it does has 1.625" (cooper "s") size bigends and a 81.3mm stroke unfortunatly any casting numbers seem to have been ground off when it has been balanced :o!
any ideas or help grately appreciated
stu
