Home > Beginners Tech > Subframe painting
evad1980
Member #: 10165
Stansted, Essex
What paint would you use for subframe painting? Por15? Hammerite?
Sand down, primer and brush on?
JT
Member #: 637
Hertfordshire
i did mine with black hammerite. seems fine but i havnt used the car yet!lol
My build thread..
adam1330
Member #: 238
essex
I got mine powdercoated...
welshdan
Member #: 1111
s wales
Hammerite is crap it cracks, flakes, chips. Got myself some chasis black from frost, good stuff, a little pricey though but worth it
oli79
Member #: 8480
Epoxymastic from rustbuster is good, Hammerite is wank
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
evad1980
Member #: 10165
Stansted, Essex
Cool.. Was also thinking about painting up the brake calipers and suspension arms, they are fairly chipped and marked. They are yellow and I'd like to keep em that colour... Any suggestions on what paint for that?
welshdan
Member #: 1111
s wales
Il be painting an engine up fairly soon hopefully, was going to order some ebgine enamel from frost, that should be good to use, unless anyone knows something better?
mercenary62
Member #: 9937
i used tractor enamel on mine ,good and tough
give em hell
Powder coat, shop around for for heavy coat and price..... job done!
Will see your great grand children Out
evad1980
Member #: 10165
Stansted, Essex
Yup think I'm swaying towards powder coating..
evad1980
Member #: 10165
Stansted, Essex
james962
Member #: 3663
Banbury
Yes I have used the Rustbuster stuff, really rate it.
Wile E. Coyote
Member #: 7893
Portsmouth
Heya All,
Just jumping in on this thread.
About to spray the subframes for mine, want to also do them yellow and a paint shop recommended a 50/50 2 pack base coat then a laquer.
Is this going to be tough enough for subframes?
I had painted with hammerite years ago, and that has all chipped off just from them being moved around the garage.
Any suggestions for a hard wearing yellow which is suitable ?
Cheers, Jamie
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Went with a semi gloss black powder coat for £130 for the pair, blasted and coated. Picking up next week.
Jamie.
Elfturbo
Member #: 2576
South Staffordshire
Anyone recommending powder coating for chassis components has never seen a TVR chassis or lotus suspension arms where the powder coat has become damaged and lifted allowing water to track underneath it.
There is a reason no volume manufactures use it on chassis.
PoR 15 behaves the same way.
HOSS
Streetscreamer
Member #: 10125
Zoetermeer, The Netherlands
Hi elfturbo, please expain about por15, as I have good experiences till now! I used that stuff many times for other kinds of components, always respected the steps of preparation, key to optimum adhesion. Let me emphasize I am not promoting por15 now, I just want to know under which circumstances were your experiences. Thanks!
Rammie2000
Member #: 10190
belgium
I have them zink sprayed and the use Hamamrite or 2k Paint over them.
