Page: |
Home > Wanted > Spi / mpi fuel tank strap | |||||||
389 Posts Member #: 9751 Senior Member Derbyshire |
1st Nov, 2012 at 02:10:14pm
I need the larger strap for my mpi tank.
6729 Posts Member #: 618 Post Whore Glasgow |
1st Nov, 2012 at 02:23:17pm
I thought the MPI tank strap was shorter than the 7.5 gal tank? I shortened mine to fit the MPI tank in mine |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
1st Nov, 2012 at 02:27:24pm
I used a standard strap on my spi tank. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
1st Nov, 2012 at 02:28:30pm
My old carb tank strap is a good few inches shorter, you've got me thinking now, I shall have a second look tonight.
1st Nov, 2012 at 02:52:05pm
you may have the strap for the smaller 5.5 gal tank? |
1st Nov, 2012 at 03:19:16pm
I may have. its a 1980 850cc. I bought the mini as a project and everything was already stripped out and lots of bits missing. |
1st Nov, 2012 at 03:43:35pm
could well be the smaller early tank then |
1st Nov, 2012 at 03:47:45pm
I have a longer strap getting under my feet in the garage. Needs a good clean and paint, but should do the job. On 11th Feb, 2015 robert said:
1st Nov, 2012 at 04:20:18pm
Sounds like a plan, pm me how much and your PayPal please. We have a shot blaster and spray booth so no problems with painting etc.
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
1st Nov, 2012 at 05:07:21pm
I found my tank strap was slightly too small for the spi tank but thats probably because the mount for it was altered when I had to repair floor section On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
1st Nov, 2012 at 05:27:16pm
Page: |
