Home > 998cc > 998 sc gearbox
burnz24
Member #: 9779
tryed searching for this but still cant get my head round this..
whats involved with building a straight cut box for a 998 and i mean everything, drops and gear but not dogged.. as i understand it the box internals are the same but do the drops differ?
like i said i just can seem to get my head round it can anyone help?
The crank is a smaller diameter where the primary gear goes on a 998, so you need a larger bush in the primary gear, otherwise it's all the same.
I believe swiftune sell straight cut drops for a 998,
Yes swift tune sell the 998 primary.
Careful that you buy the whole drop-gear train from Swifty as the primary gear is not compatible with the MS idler and input gear. Don't ask me how I know :(
Edited by Paul S on 17th Oct, 2012.
Chalkie
Member #: 9764
Northamptonshire.
Didn't someone do a kit that pressed into the 1275 bush to make it fit/
madminimart
Member #: 4373
Yeovil, Somerset land
I got a bush from this forum, think it was from joeybaby83. Was a long time ago.
Just replaced the bush in the 1275 primary gear so it could be used on 998 crank.
burnz24
Member #: 9779
cheers for that, pretty simple then..
dont know why i couldnt understand it.. one of them days i reckon..
I'm sure any machine shop with a lump of the correct brass and some measurements could make a new bush to drop the 1275 gear down to 998 size.
Phosphor Bronze would be a better material to use *wink*
Edited by John on 18th Oct, 2012.
Looks like Joey is still alive and kicking!
http://www.ebay.co.uk/itm/Classic-Mini-Pri...h-/170925215084
pieter
Member #: 7577
belgium
i have bought such a bush from med when i bought my sc drop gears from them...
