Page: |
Home > 998cc > 998 Turbo | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
4th Jun, 2005 at 08:48:11pm
Hi, Edited by Tom Fenton on 7th Nov, 2005. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Jun, 2005 at 11:46:25pm
Hello and welcome...
AlexF |
5th Jun, 2005 at 09:33:08am
The challange for me is to get an economic everday road engine that has lots of power in reserve for when you need it.
![]() 1014 Posts Member #: 238 Post Whore essex |
5th Jun, 2005 at 05:42:47pm
why not use an 850cc then? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
5th Jun, 2005 at 07:28:05pm
I read the Vizard book about 25 years ago and having dug it out of my loft recently and read it again, got the distinct impression that the 850 does not lend itself to any serious mods. The lack of cam bearings, lubrication to the bottom bearings etc.
5th Jun, 2005 at 08:39:45pm
Thanks for the good advice mini1071s.
![]() 7 Posts Member #: 2958 Junior Member Concordia |
31st May, 2009 at 11:39:28pm
Where could one find more info on the 850 crank in a 998? It's in the works |
1st Jun, 2009 at 01:11:58am
On 17th Feb, 2009 Rob H said:
1st Jun, 2009 at 06:44:44am
Bookmarked a over a year ago on an old computer that only works half the time. The subject came up on another forum... I was determined. It took about 3 days and tearing apart and rebuilding a laptop to find it. I've got a 998 setting in the garage wait for me to do something with it. Just searching for as much info on options of interest prior to starting. It's in the works |
1st Jun, 2009 at 09:17:23am
Blimey, my first post. Almost 4 years ago and I'm only just getting round to fitting the turbo.
Edited by Paul S on 1st Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Jun, 2009 at 12:03:21am
Thanks for the references. I've been reading them slowly this afternoon. What are the benifits of the larger bore w/shorter throw? I know higher revs but is that where you get the boost in mpg? And my last question for now. Wouldn't your torque and hp figures drop, at least in low end RPM? If I just need to keep reading that's not a problem. I have a habit of jumping the gun. It's in the works |
2nd Jun, 2009 at 08:05:37am
The same rules apply to a turbo motor as a N/A. So longer stroke = more torque, less revs. As a general rule.
http://www.twin-turbo.co.uk
Page: |
