Page: |
Home > A-Series EFI / Injection > EFI Self Tuning system | |||||||
2 Posts Member #: 10126 Junior Member |
1st Oct, 2012 at 09:14:33am
Hi guys
1st Oct, 2012 at 09:34:51am
Most good ECUs will self tune the fuel map from a wideband reading.
1434 Posts Member #: 8466 Post Whore Mansfield |
1st Oct, 2012 at 09:42:21am
If only they were really that simple. Most Ecu's have closed loom lamda control, but building a decent map using it takes time and effort. Class C 3rd Place Avon 2011 14.18 @101mph |
1st Oct, 2012 at 09:46:23am
I found the MS VE Analise Live quick and simple to set up the map (then used the injection timing to balance the inner and outer cylinders whilst VEAL carried on doing its job)
1st Oct, 2012 at 03:05:42pm
Thinking about this a bit more.
Edited by Paul S on 1st Oct, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
834 Posts Member #: 2017 Post Whore Warwick. |
1st Oct, 2012 at 06:23:08pm
Used these type systems at the last place i worked. On rally 205's mostly. Require you to drive round with laptop hooked up, lambda in for such a number of miles. more you drive the better it tunes.
David. |
3588 Posts Member #: 655 Post Whore Northern Ireland |
1st Oct, 2012 at 06:54:49pm
Not Snake Oil as such. But people have far too high expectations of "self tune" systems
11046 Posts Member #: 965 Post Whore Preston On The Brook |
1st Oct, 2012 at 07:25:11pm
Most if not all have a self tune facility, but they are far from user input free systems.
1st Oct, 2012 at 07:34:40pm
On 1st Oct, 2012 Sprocket said:
as for self tuning the ignition, never ever heard of it, and it would be a fools game if there was such a set up. At the very least it would require knock sensors and be able to calculate cylinder power. Would you trust your newley built expensive engine to a computer to determine the ignition advance? I would trust it if it had in-cylinder pressure sensors and the needed setup to get the timing accuracy not to mention the hardware needed for processing this data. With that you could find the optimal ignition timing and detect any knock. You can get sparkplugs with the pressure sensors but it would be in the order of $20k or something like that to get a working system and I'm not sure you could run with it on a regular basis or could only use it for tuning purposes. Jean |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
1st Oct, 2012 at 08:57:40pm
someone needs to adapt the saab ion sence ignition module for general use. Self tune just helps you along, youd be a fool to rely on it :) turbo 16v k-series 11.9@118.9 :)
1st Oct, 2012 at 10:10:38pm
On 1st Oct, 2012 evolotion said:
Self tune just helps you along, youd be a fool to rely on it :) My point exactly :) On 26th Oct, 2004 TurboDave16v said:
Page: |
