Home > General Chat > r1 versus 1275 engine weight
mercenary62
Member #: 9937
just thought id compare engine weights, mini 1275 engine with box and all ancillieries 155kg, yamaha r1 engine complete with ancillieries and loom just under 80kg i know which route im going yam r1 lynx kit il let you know how i get on with this project
give em hell
Epoxy69
Member #: 9868
Petersfield, Hampshire
Out of curiosity, what made you choose the lynx kit?
I eventually intend on doing an R1 install and the promotive kit seemed like it gave you more for your money aswell as offering more extras. Only con as far as I can see is having to remove your subby, where as the lynx cradle drops straight in once the old A series is removed!
Knowledge is never a burden, so fire away!
mercenary62
Member #: 9937
i personally like the lynx kit as you can if you wish remove the complete install in a wk end and plonk in an old a series for different applications also lynx will sell you the seperate components if your on a budget like i am ,plus it looks like a neater install to me
give em hell
Epoxy69
Member #: 9868
Ah, touché.
I'll keep an eye out for your build thread!
mercenary62
Member #: 9937
just listed it mate in show us yours
give em hell
Epoxy69
Member #: 9868
Mines gonna be A-series for another year or so, unfortunatly!
mercenary62
Member #: 9937
nothing wrong with the good old a series mate ,ive been there done that so time for a change
give em hell
jamie@thefatgarage
Member #: 9345
Sheffield
Out of curiosity..why spend a fortune for an engine with 70-80 Lb/ft of torque designed to haul around a bike weighing <200kg?
mercenary62
Member #: 9937
have you seen one in action mate ,have a look 0 t0 60 in 4.5 ish and fairly rapid up to and over 130 mph then theres the noise ,mind you il probably be deaf after the first week lol
give em hell
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
can't beat a good A series turbo for power and sound
16V project underway
What I would like to see is a turbo R1 mini.
Amp
Member #: 7856
I've seen one burnt out in a breakers yard before! Got some pictures somewhere of it...
You say there is a 75kg difference but how much does the frame, diff and chain weigh? i know not 75kg but is still a fair weight.
My biggest concern would be that the bike engines seem very forward of the effective front axle
Reverse gear is a bugger *hehe!*
I suppose you could always cut a hole in the floor and Flintstone it
oli79
Member #: 8480
The relative lack of torque is not the issue everyone makes it out to be due to gearing, after all the bikes are geared for 180 mph plus, the minis are dropped to around 110-130 mph flat out, and that mechanical advantage is needed due to the size of the clutch also. I have always been interested in these r1 fwd conversions but never tried one, what has put me off the r1 is having owned a hayabusa z cars mini, I raced it along side a guy with an equivalent r1 engined car, on paper he had a lighter car by 30kg and only 30 or so HP less but the difference was considerably dramatic, I will have a look for the vid, maybe there is something to be said between the torque output between 1000/1300 cc bike engines.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
mercenary62
Member #: 9937
reverse gear is by electric motor mate ,and i only chose r1 as im no millionare, r1 engine costs between 600 pounds and 1200 pounds to buy depending on milage , hayabusa engine is 2000 pounds and upwards for a descent engine
give em hell
quote=jamie@thefatgarage,29th Sep, 2012]Out of curiosity..why spend a fortune for an engine with 70-80 Lb/ft of torque designed to haul around a bike weighing <200kg?
[/quote]
CORRECT !!
oli79
Member #: 8480
Listen i aint knocking it, Ive been there, for me the total cost of a z cars build (around £16000 iirc ouch) to the difference in prices at the time between an r1 £1500 to a busa at £2800 was a drop in an ocean! Here's the vid mines the orange one, at the start I take it steady because his dad is in my car and he was driving like a twat on a busy twisty bit, at around 1 min in on the main road I give it a tube opener.
http://video.google.co.uk/videoplay?docid=...574000&hl=en-GB
Ps;If you think a front drive will be loud, you should try having it in the car next to your left ear!
oli79
Member #: 8480
Another one of my car there, with guy called chops? filming-he liked it!
http://www.veoh.com/watch/v10220496BkKjM5D...ini+on+creg+run
The problem with the mechanical advantage is that the strain on the transmission is greater. I've seen broken transmitions and chains, and the clutch slip required to get the thing moving ends with clutch replacement at frequent intervals. The fact that there is no reverse gear means as has already been stated to add another starter motor and ring gear onto the chainwheel.
so, while the engine itself might be light and produce 100's of hp, the lack of reverse gear, or a diff will resultantly add a significant weight to the car, when you look at a like for like package.
As for the cost, for £4500 you could have a far more powerful A series turbo motor than the R1
Its just a fad.
Bike engines for bikes and car engines for cars.
Just my opinion *wink*
oli79
Member #: 8480
I agree with all that apart from the clutch slip issue on my particular set up, setting off was not a big problem at all and clutch wear negligable. The z cars reverse option weighed a ton and it had all the power of one of my beer farts. There was a whole discussion about it 5 years ago not so much the mechanical advantage that caused a problem with the transmission, more a lack of any type of cush drive which bikes do have,shock loading blah blah ect ect. Imo the z cars bike engined cars only worked as really light stripped out track racers and with people who overlooked the mechanical short comings, mine was not a good road car.
Its just a fad.
mercenary62
Member #: 9937
shouldnt be much clutch slip if at all any as r1 develops much the same torque as a std mini 1000 engine ,i know of a guy with an r1 conversion that can pull away from idle
give em hell
moke123
Member #: 4584
Perth, Australia
watched these 2 videos and LOVED the sound!
