Page: |
Home > 998cc > rockers | |||||||
239 Posts Member #: 7577 Senior Member belgium |
31st Aug, 2012 at 08:26:34am
hi,
31st Aug, 2012 at 09:26:32am
Use what you Like Think on;y 1.3.1 ratio can be used on 998 though if you go roller rockers |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
31st Aug, 2012 at 09:36:19am
why is that?
On 31st Aug, 2012 Chalkie said:
Use what you Like Think on;y 1.3.1 ratio can be used on 998 though if you go roller rockers http://www.twin-turbo.co.uk
114 Posts Member #: 9645 Advanced Member South Wales |
31st Aug, 2012 at 09:42:07am
There is something in the yellow book about using 1.5 ratio's on a 998 and I think he found they gave worse results than the 1.3's. I guess it would depend on the lift of the cam that you are going to use as well. Kent Cams don't recommend using 1.5 ratio on 998 either.
31st Aug, 2012 at 11:44:02am
There is no blanket rule to say that you can't use 1.5s on a small bore. The yellow book does talk about it, but there are plenty of engines that have benifited from them.
Edited by Ben H on 31st Aug, 2012. http://www.twin-turbo.co.uk
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
31st Aug, 2012 at 12:04:55pm
Roller rockers are only to stop premature valve and guide wear by stopping the rocker pushing the valve at an angle, theyre only necessary if there is excessive sweep on the valve stem top.
Edited by paul wiginton on 31st Aug, 2012. I seriously doubt it! |
31st Aug, 2012 at 01:49:02pm
i was planning on fitting 1,3 minisport rockers but i have just ordered an xlite flywheel from med so the piggy bank is empty for now...
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
31st Aug, 2012 at 03:35:52pm
The minisport ones i have had in my hands after a bit of running where all quite sloppy. I would either keep stock or invest more .
Edited by Sir Yun on 31st Aug, 2012. That sir, is not rust, it is the progressive mass reduction system
31st Aug, 2012 at 06:17:29pm
Standard roller rockers are incorrectly spaced for a 998.
4th Sep, 2012 at 08:34:38am
thanks for all the info guys, i'll keep the stock ones. i am now in the midst of building the turbo gearbox and engine and hope to get some decent process done in the next week. i'll stick to the standard rockers for now |
882 Posts Member #: 9774 Post Whore Buckinghamshire |
4th Sep, 2012 at 09:57:20am
So how far do you space them? Just so that the rollers are central on the valves?
On 31st Aug, 2012 Paul S said:
Standard roller rockers are incorrectly spaced for a 998. You need to re-arrange the rockers and add spacers. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
4th Sep, 2012 at 10:20:29am
It'll become obvious when you try to fit them. The roller tips are offset from the rocker. Some will med swapping over to align the tips with the valve stem. In the 13's at last!.. Just |
Page: |
