Home > Good Garages & Parts Suppliers > Can anyone recomend a good reconditioned turbo supplier or repairer?
AdCel85
Member #: 10089
Newcastle Upon Tyne
I am running a t3 metro turbo at the moment but getting a bit of smoke, I suspect the seals have gone on the turbo. can anyone recomend a good supplier or repairer?
josh_28
Member #: 9698
Pembrokeshire, Wales
Cr turbos have been reccomended to me a few times
AdCel85
Member #: 10089
Newcastle Upon Tyne
Thanks Josh!
make sure it is the turbo that is smoking though and not stem seals
bennyy
Member #: 9037
Doncaster, yorkshire
Cr turbos or turbodynamics
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
AdCel85
Member #: 10089
Newcastle Upon Tyne
The engine has been fully rebuilt with new +20 Omega pistons etc and all the seals were done then - just done 600 miles sinec the build and getting fed up of the smoke now, do you think it is worth a compression test?
bennyy
Member #: 9037
Did it smoke before the rebuild? Still could be seals even though they were changed.
Check see if they have lifted.
AdCel85
Member #: 10089
Newcastle Upon Tyne
I dont know that because the engine was bought and rebuilt but I had never ran it before the rebuild. I ran the engine n/a for a few mins once it had been rebuilt and no smoke. As soon as the turbo was put on there was loads of smoke but it gradually got less as time went on and now it is a constant amount but it gets on my nerves so was going to replace the unit.
CR turbos provide an excellent service.
