Home > Show Us Yours! > Water Pump Engine Steady
topcat
Member #: 9408
Tiptree, Essex
Hi all,
I've not been impressed with any of the engine steady kits available, the DSN one looks nice but to me seems like overkill, and I still don't like the idea of using the thermostat bolts for anything other than the stat!
So, I've been making up an aluminium bracket that bolts on to the WP, CNC milled here, I'm going to make a bracket to weld onto the crossmember, and tie it in the same as the steady on the OS with a plate on the top too. Will have a rose joint on one end and rubber bush on the other, anyone else interested?
Here's a pic, will be trying to get the other bits made up shortly!
TC
p.s. the bits in the background are the prototypes, and the latest shape weighs 61g in 5mm ally :)
Edited by topcat on 30th Aug, 2012.
www.topcatcustom.co.uk
Chalkie
Member #: 9764
Northamptonshire.
They do look pretty cool what sort of price you be selling them at?
bennyy
Member #: 9037
Doncaster, yorkshire
Minispares already do those
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
topcat
Member #: 9408
Tiptree, Essex
So do W&P, and they're heavy steel listed at 1kg, and with crappy wide bushes in single shear!
Hope to make them cheap enough to consider instead of the steel ones Chalkie!
Yo-Han
Member #: 3228
North of the Netherlands
I might be interested dependant on price and if it would fit together with the supercharger belt that will be pretty close to this.
Dazed and Confused....
topcat
Member #: 9408
Tiptree, Essex
It fits behind the WP pulley by approx 9mm (off the top of my head), does the blower drive go infront?
Kean
Member #: 341
aka T2clubby
South Staffs
They look nice, but I have concerns about using the water pump bolts. At the point that the bracket mounts to the bolts is about an inch from the block, would this not put extra stress on them?
However, I cannot see how else you would do it in that area...
mossy2a
Member #: 9751
Derbyshire
I'd be interested, price dependant.
topcat
Member #: 9408
Tiptree, Essex
Kean, personally I think it is better than using the small thermostat bolts that most use, and the water pump is a nice rigid piece of ally that provides a good solids spacer for the bracket to mount to.
By using 2 fixing holes over 3" apart I think it helps too.
I did consider using other points, such as the water bypass hole with a big thread under the head (thermostat end) but wasn't sure about it, although it could still make a decent position, with a steel top hat wound in tight, providing a point to bolt a rose joint to perhaps?
Anyway these should be strong enough, I'm pretty adamant that I want to use a weld on bracket to the cross member, although this could be bolted through but wouldn't be as strong.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I made one of these for my engine and so far it has worked great. I used a cut down rod from Carl to link to the bulkhead.
I have an extra bend in mine to move the bracked on the bulkhead towards the inner wing. It give a little more space for the turbo inlet.
http://www.twin-turbo.co.uk
Kean
Member #: 341
aka T2clubby
South Staffs
I agree with the thermostat bolts also. On my old engine all I had was one rose jointed steady in the normal position, and normal rubber engine mounts. Maybe its my driving style but I never had any need for extra steadies.
topcat
Member #: 9408
Tiptree, Essex
Just knocked up the "rod" part, so long as there is plenty of thread in the ally I think it should be strong enough, I was thinking about doing one in titanium but a bit overkill where there is a 30year old lump of cast iron sitting next to it creating most of the weight!
also once the length is set, I reckon it would be a lot stronger if the thread was loctited in, so may be worth doing it in ally.
Kean
Member #: 341
aka T2clubby
South Staffs
Looks very nicely done
wng691s clubby
Member #: 9252
Cleethorpes
looking good what sort of price are you thinking? a picture of it fitted would be good too *happy*
Edited by wng691s clubby on 30th Aug, 2012.
Done now needs redoing lol
topcat
Member #: 9408
Tiptree, Essex
Got to fit it first! Also my bearing supplier doesn't think he can get rose joints with a thread longer than 25mm, seems a bit daft, will ask him to look into it I think.
