Page: |
Home > 998cc > 998 Turbo - Standard head | |||||||
113 Posts Member #: 9241 Advanced Member Edinburgh / Dumfries |
21st Aug, 2012 at 02:40:46pm
Hi all, Hope this hasn't been asked before!
21st Aug, 2012 at 03:18:47pm
Ask Benross he'll be your man but it should be fine if the compression is dropped |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
21st Aug, 2012 at 04:02:20pm
They flow poorly, but if you're on a budget & must use one then have a look in Vizards big yellow book, mods to this head are covered extensively.
Edited by Turbo Phil on 21st Aug, 2012. |
21st Aug, 2012 at 04:42:24pm
OK, maybe I'll have a think....
Edited by wagon_rider on 21st Aug, 2012. |
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
21st Aug, 2012 at 10:12:15pm
Get yourself a 295. Even in standard form they are far better than a lightly modified 998 head. Just change the exhaust valves for some one piece ones. On 13th Jul, 2012 Ben H said:
774 Posts Member #: 6724 Post Whore Wootton Bassett |
21st Aug, 2012 at 11:44:24pm
I made a nice road motor by using a standard head and grinding the chambers to a better shape. Ran a T2 and 8 psi of boost. Needed a bit of refining but worked well.
22nd Aug, 2012 at 06:20:53am
I don't believe that the 295 was the reason for loosing low end torque. Could it be something different? On 13th Jul, 2012 Ben H said:
118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
22nd Aug, 2012 at 08:43:12am
Does anyone have any patterns for modding a 12G202, looking for something similar cc as a 295 maybe a bit bigger? “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
22nd Aug, 2012 at 08:49:24am
'spose an extra £100 for a 295 on top of everything is small beer really!
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
22nd Aug, 2012 at 08:55:38am
The problem with 295's is finding a usable one for sensible money. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
22nd Aug, 2012 at 11:51:16am
On 22nd Aug, 2012 Vegard said:
I don't believe that the 295 was the reason for loosing low end torque. Could it be something different? I suppose it wasn't technically the 295 but it was because of fitting that lead to a lower cr (from 10:1 to 9:1) which was by design/ choice. |
27th Jan, 2014 at 11:25:02am
Does anybody have any pics of standard 998 heads with mods please? :) |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
27th Jan, 2014 at 11:32:53am
We're having a problem finding a 295 for not stupid money too. It's making me consider other options that might be available instead of shelling out £150 for a head that still needs work and parts to fit it. Just wondering if could you get enough meat out of a 940 to use on a 998t engine? for something around 80bhp not the usual 100odd people aim for. On 26th Jan, 2012 Tom Fenton said:
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
27th Jan, 2014 at 12:01:43pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=537811
28th Jan, 2014 at 08:52:28am
imo depending on what your after i believe if your prepared to have someone that really knows there stuff do a head and spend the time then to start with a 202 as you have the opatunity to have good high speed ports and nice bowl/valve seat same for the chamber shape you can get it how ever you want it i think most of this is aplicable to a low rpm high tourqe engine ie small ports have high air speed but dont flow to well at high rpms |
Page: |
