Page: |
Home > A-Series EFI / Injection > 12volt to 5volt for Ecu Aux | |||||||
1434 Posts Member #: 8466 Post Whore Mansfield |
19th Aug, 2012 at 11:55:30am
Can anybody tell me how to reduce a 12-14v volt down to a 0-5 volt signal to my Dta Ecu. When I activate nitrous in want the ecu to retard ignition. Class C 3rd Place Avon 2011 14.18 @101mph |
19th Aug, 2012 at 12:25:57pm
I'm not familiar with DTA but it must have a 5V out for all it's sensors.
19th Aug, 2012 at 12:33:54pm
Yes, just want a 5v on/off. The Dta does have 5v out. I was originally thinking using the circuit from a 5v in car mobile charger. Edited by alaskanow0 on 19th Aug, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
19th Aug, 2012 at 12:56:59pm
Use the DTA's own 5V, not an external one - it's own one will be ground referenced within the ECU box.
19th Aug, 2012 at 02:00:03pm
Thanks Rod, relay it is. Class C 3rd Place Avon 2011 14.18 @101mph |
3588 Posts Member #: 655 Post Whore Northern Ireland |
19th Aug, 2012 at 02:58:30pm
On 19th Aug, 2012 alaskanow0 said:
Can anybody tell me how to reduce a 12-14v volt down to a 0-5 volt signal to my Dta Ecu. When I activate nitrous in want the ecu to retard ignition. Exactly how are you configuring this ? You could use an Aux out on the DTA to actually trigger the nitrous ( via TPS, RPM, whatever ), and in doing so automatically apply any fuel/timing compensations in the relevant Aux out table. 9.85 @ 145mph
11046 Posts Member #: 965 Post Whore Preston On The Brook |
19th Aug, 2012 at 03:59:06pm
The way I controlled the nitrous was using a the ECU settings. The nitrous controller in the ECU is 'activated' by a toggle switch on the dash which simply grounds one of the digital inputs to the sensor ground. Most ECU digital inputs are 5v pull up internally so that when grounded it pulls the 5v to ground, thus it is either on or off. Above 90% TPS the ECU grounds the output that is connected to the progressive nitrous controller's activation input (normally the micro switch on the throttle)
Edited by Sprocket on 19th Aug, 2012. On 26th Oct, 2004 TurboDave16v said:
19th Aug, 2012 at 09:50:14pm
Can anybody tell me how to reduce a 12-14v volt down to a 0-5 volt signal to my Dta Ecu. When I activate nitrous in want the ecu to retard ignition. Exactly how are you configuring this ? You could use an Aux out on the DTA to actually trigger the nitrous ( via TPS, RPM, whatever ), and in doing so automatically apply any fuel/timing compensations in the relevant Aux out table. Class C 3rd Place Avon 2011 14.18 @101mph |
2233 Posts Member #: 9037 Post Whore Doncaster, yorkshire |
19th Aug, 2012 at 10:08:41pm
Matt this doesn't suprise me one bit, lol Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
21st Aug, 2012 at 02:15:57pm
That was the plan, but wasn't sure how to activate aux only when nitrous was in use. I see what you're saying. If you want to change a 12v trigger to a -neg ve trigger. You could use a small NPN transistor or micro relay, or a big relay. You could then use this -ve trigger to activate MAP2 on the DTA which would carry the relevant changes for nitrous use. Or maybe wire in an IAT sensor into an Analogue input on the DTA. When nitrous is spraying IAT's will drop, and you could then use this cooling reference to apply any fuel/timing corrections That way they will only be applied when it is actually spraying. 9.85 @ 145mph
Page: |
