Home > 998cc > Garrett GT2554R Ball Bearing
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
has anyone used one before ?
http://www.turbobygarrett.com/turbobygarrett/turbocharger
had a quick search and didn't find much on this model ive herd ball turbos are better than journals is this true?
Would that not be far too large?... Especially on a 998.
bennyy
Member #: 9037
Doncaster, yorkshire
This is huge, far to big on a 998, me and brett have a plan for our next turbo, includes a bb core.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Oi sshhh
benjamin
Member #: 621
nsw austalia
I use a gt2554r on my 1100 , iv used a custom .49 turbine instead of the .64 and i see full boost arouund 4400rpm (15psi)
http://www.turbominis.co.uk/forums/index.p...id=232044&fr=25
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
thought it was on the large side but dont the bbs take less to spin up?
ive never done a turbo motor but im going to give it a go as to how im going to do it i have no idear
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
ben love ur clubby grate work id love to do something like that so the hypatecs hod up ok? id have thought you'd need something a bit better no? is that all you had to do with the turbo change to a custom wheel? cam choice?
lots of questions as id like to do basically the same thing
scratch that found your build log
Edited by Turbo This.. on 14th Aug, 2012.
benjamin
Member #: 621
nsw austalia
hypatecs are ok , but i did end up cracking a ring land after 20,000km and 15psi, When it goes back together this time i will be using Graham russel pistons which dont have the oil slots.
