Page: |
Home > How To > megajolt lead drivers serial to usb | |||||||
2057 Posts Member #: 9252 Post Whore Cleethorpes |
12th Aug, 2012 at 06:39:10am
serial to usb drivers for nearly all operating systems and they work with Plugable USB to RS-232 DB9 Serial Adapter from maplins
Done now needs redoing lol |
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
12th Aug, 2012 at 08:22:16am
Top man, this will be well helpfully for many members
12th Aug, 2012 at 09:10:36am
i thought i would share as i had problems with mine this is a generic driver so should work with all converters and also works on windows 7 but not 8 as there out dating this chip set and a different lead is need for windows 8 Done now needs redoing lol |
225 Posts Member #: 3772 Senior Member Wigan |
12th Aug, 2012 at 02:14:38pm
cheers for that, id just ordered a usb to rs232 cable last night.
12th Aug, 2012 at 02:21:56pm
just needs to be able to power up have a look at the autolab website make sure your using the correct software for the unit so they match as i wasnt and i got errors Done now needs redoing lol |
12th Aug, 2012 at 03:52:23pm
so if i stick the live and earth on it i can get in without edis etc connected
12th Aug, 2012 at 04:01:05pm
yup, i belive you can do it with a 9v battery its all on there site tho id have a read to double check Done now needs redoing lol |
336 Posts Member #: 9941 Senior Member Derby |
29th Jun, 2013 at 06:57:20pm
That lead recommended above is the one u have Andy, lol it worked on mine man lol I'm sure u will sort it though |
Page: |
