Home > 998cc > 998 Pockets Tech Drawing
Chalkie
Member #: 9764
Northamptonshire.
Hey guys here's the 998 Pockets Tech Drawing for download
(be good if this got topped)
Hope this Helps
Stephen
Nice one ! Thanks for sharing. I presume the cutouts are to provide clearance for the 29mm ex valve ?
Edited by Turbo Phil on 8th Jul, 2012.
Chalkie
Member #: 9764
Northamptonshire.
I think so Phil not 100% sure
well exhaust valve is 29mm and the Radius is 18mm so if I remember right Radius is twice size of Diameter?
Edited by Chalkie on 8th Jul, 2012.
Sam
Member #: 1686
Oxford
Half the size of the diamater.
OMG Robert that's a big one
408.Luke
Member #: 9909
Tyler, Texas
Awesome! i was just looking for something like this! Greatly Appreciated
-1974 Mini 1000 - BRG Turbo Build Soon to come
-04.5 LLY Duramax - RC/LB - White - Built Trans - EFILive - Dropped 4/6
-2013 TDI Passat - SEL - White - Lowered on Coilovers - Daily Driver
-2003 Silverado SS - 408 Stroker - DP NO2 - Full Suspension ~900hp For Sale
Rammie2000
Member #: 10190
belgium
Idemdito as luke... so the valve centre sits 2, 24 mm more to the back as the bore centre... how deep would you go?
jlay
Member #: 1742
essex
Depth depends on if the blocks been skimmed, piston crown to ring grove, how far down the piston is from block surface, how much value lift you got (valve above head surface) then give a little clearance.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Chalkie
Member #: 9764
Northamptonshire.
5mm the drawing gives
Rammie2000
Member #: 10190
belgium
its all metro standard stuf. head been skimmed once. i have 1 mm clearance now. how much should i have to be ideal? i ran it once with that 1 mm for a week but inlets came white so took it back of.
Edited by Rammie2000 on 8th Sep, 2013.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
surely if the big valve is in a small bore than the extra flow the valve gives is sacrificed due to the block shrouding the valve
i think that the standard head/block arrangement is poor due the the std head being larger than the bore to start with surely this over hang is a bad thing?
Chalkie
Member #: 9764
Northamptonshire.
They do say not to put a Big valve head on.
On a standard valve setup it be okay a little bit is sacrificed due to the block blocking it but not too much
You could blend the pocket into the bore its self, gain some flow around the piston area but not sure how this will fair up
jlay
Member #: 1742
essex
but the 998 head chamber over hangs the block also its only because the chamber depth is different.
408.Luke
Member #: 9909
Tyler, Texas
Shrouding will kill the flow of the head and cause less power on that head, but not necessarily less power for that motor. I don't know all the flow numbers for these heads, but i would guess on a smaller displacement engines it could cause an over all power loss. However when its boosted, its all being shoved in anyway so the effect will not be as pronounced. I am pocketing my block to fit a SC 7 port head and not just a standard big bore head. I know there will be shrouding, but its the best compromise for me.
jlay
Member #: 1742
essex
there was an article in one of the keeping a mini alive magazine specials they wanted to see what was possible with a small bore engine. they started off building a plus .040" bore "special cam" engine with 10.5cr but running a 1.5" carb and ported small bore head. They had pocketed the block ready for next stage. it was dyno'd and run in. then they swapped carb for hiff 44 re dyno then swapped head for a ported 12g940 keeping same compression ratio and then re dyno'd the head and carb conbo made large difference and I believe they peaked at about 90bhp. I will try to dig it out and confirm the figures
Rammie2000
Member #: 10190
belgium
if i mesure the valve on the big bore and on the small bore i do see that although it over hangs the free part is still bigger than a standard 998 head.
Chalkie
Member #: 9764
Northamptonshire.
I've seen this done before (Excuse the shit picture I used Paint)
But blending the pocket into the bore would this give any better Combustion and flow around the bore area as it flows with the bore and not just a milled in the block?
Rammie2000
Member #: 10190
belgium
Wouldn't you expose evan more ring to hot gasseson this way?
Chalkie
Member #: 9764
Northamptonshire.
I didn't come up with the idea :] why I asked
but i'm sure that could be a factor in its floor
I wanna know how possible 7/8 ports are on 998's
Rammie2000
Member #: 10190
belgium
Question. Getting the block pocketed tomorrow but for the build... do i use 1275 puchrods or the original ones?
Chalkie
Member #: 9764
Northamptonshire.
No you use the 998 push rods
1275 blocks are taller than 998 ones
Rammie2000
Member #: 10190
belgium
Right its the block thats higher. . Deuuh. Forget that i asked. Big head ,twin 1, 25s... can't wait.
Chalkie
Member #: 9764
Northamptonshire.
Nice!! Im tempted on a benross 12g295 or a 940 lightly done
with fuel injection :]
Rammie2000
Member #: 10190
belgium
does it have to be drilled 5 mm? how much mm is there from deck of the piston to the ring? i have flat tops ( come fluch with the block deck made 11 cr with modded 998 head) in the block right now. going to drill them in but without removing pistons. ( they will be closed of by a rubber insert and grease so the debree cant fall in to the ring land)
grtz
Edited by Rammie2000 on 1st Oct, 2013.
sim_ou_nao
Member #: 114
Porto/Portugal
Can anyone tell if there is a minimum distance between the pocket and the top of the first ring? if so, what is the minimum distance?
Pedro Silva
Rammie2000
Member #: 10190
belgium
i left about 3 or 4 mm as i remember. its been about 1.5 or 2 years now ridding it hard and still goes
