Page: |
Home > Show Us Yours! > Blitz 2 Turbo... | |||||||
665 Posts Member #: 9345 Post Whore Sheffield |
25th Jun, 2012 at 07:34:28pm
Couldn't resist buying a Blitz 2 kit car to turbo. Already road registered and tax exempt. Going to use the engine/box/etc from my mini. Should be a laugh... Hopefully a quick project not a full strip and start again, and then I'll decide what to do with the mini (rebuild / sell / break).
971 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Jun, 2012 at 08:30:44pm
Looks like a lot of fun!
Dazed and Confused.... |
25th Jun, 2012 at 09:03:09pm
Yes, that might not stay either... but it may become a hoist for the garage.
On 25th Jun, 2012 Yo-Han said:
Looks like a lot of fun! Even spot a winch..?! |
1755 Posts Member #: 8852 Post Whore leicestershire |
26th Jun, 2012 at 10:29:28am
Is that a nikki downdraught ? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
2233 Posts Member #: 9037 Post Whore Doncaster, yorkshire |
26th Jun, 2012 at 10:57:28am
What happened to the mini? Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
26th Jun, 2012 at 10:57:32am
Not sure, didn't look too hard. I'll look at the weekend.
On 26th Jun, 2012 eden7842 said:
Is that a nikki downdraught ? |
16th Jul, 2012 at 01:06:16pm
I think it is one. It's certainly a nikki manifold, and it has a GM in the casting on the carb.
On 26th Jun, 2012 jamie@thefatgarage said:
Not sure, didn't look too hard. I'll look at the weekend. On 26th Jun, 2012 eden7842 said: Is that a nikki downdraught ? |
16th Jul, 2012 at 01:16:17pm
Help needed time. I need to remake the arrangement that holds the steering arms to the subframe at the back. The existing method is a bit shit.
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
16th Jul, 2012 at 01:33:14pm
Will be interesting with a Turbo motor in you will have great fun! Do compleate the mini as well
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
16th Jul, 2012 at 01:34:43pm
Id bang a FB Shell over that like a spaceframe! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
16th Jul, 2012 at 02:33:52pm
Fast Carl should be able.to sort some shafts for you On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
16th Jul, 2012 at 03:12:26pm
Make sure you attach the shafts at the correct point (height), this to reduce/prevent bump steer.
28th Jul, 2012 at 06:32:27pm
Update. Engine and subframe in, chassis modded for rear (ex front) coilovers. Wheels pointing right way and note taken on the bump steer comment (thanks for reminding me). |
27th Oct, 2012 at 05:02:40pm
Some shit progress pics.
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
27th Oct, 2012 at 05:17:35pm
Rear bump steer will be bad methinks!?? This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
27th Oct, 2012 at 05:20:24pm
Which is why I have aimed for 0 and will settle for little.
On 27th Oct, 2012 steve w said:
Rear bump steer will be bad methinks!?? |
27th Oct, 2012 at 05:29:09pm
Fair play!
27th Oct, 2012 at 05:36:34pm
It's an aftermarket one for an MR2 I think. Had it a while so not sure. Not custom anyway. |
Page: |
