Home > General Chat > removing pistons from rods
mercenary62
Member #: 9937
hi does anyone know how to seperate my fugged pistons from the rods,do you need a press,seem to be on to stay they are turbo pistons and rods thanks
give em hell
If they are scrap, sit the piston side on in a vice and drift the pin out.
danb41
Member #: 9285
Oxfordshire
Cost me a tenner for a local machinist to separate a set of pistons from the rods.
mercenary62
Member #: 9937
thanks for that
give em hell
tadge44
Member #: 2500
Buckinghamshire
I made a hardwood jig to protect the piston, shaped to conform to the diameter, and turned up pins and a spacer to push the gudgeon out, using a large vice. Those that were stubborn I took round to the local garage and used their press to push them out.
Contrary to advice received on here I did not use any heat and have successfully re-fitted more than one set of pistons the same way.
I used Andy's method with success, and a some tapping with the sledge hammer.
mercenary62
Member #: 9937
pistons now off rods i heated the small end with a blowlamp and hammered out using a drift
give em hell
tadge44
Member #: 2500
Buckinghamshire
How are you going to put them back ?
Not with a sledgehammer I hope !
I use some large cap head bolts and an old piece of suitable tube. I place the piston in a large vice side on with the pipe one side, then put the cap head against the pin and wind the vice in.
Only on scrap pistons of course!
I've done the exact same thing with hardwood although I'm using a proper press.... If you heat them in the way in, it makes things easier.
mercenary62
Member #: 9937
bought rods s/h with good pistons on so il now use them so my turbo rods will be up for sale
give em hell
There's no such thing as turbo rods.
eden7842
Member #: 8852
leicestershire
I heated mine up and just pushd them out with a screwdriver
JT
Member #: 637
Hertfordshire
old thread revival!!
Hi
Basically I have a set of forged omega pistons I bought years ago. There on standard rods.
I have a set of lightened and balanced rods with no pistons on.
Is there a way I can remove my pistons without damaging them and refitting them to the lightened and balanced rods? Safely?
Thanks
Josh
My build thread..
sim_ou_nao
Member #: 114
Porto/Portugal
There is always a risk, but you can warm up the rod, to make it easier
Pedro Silva
slater
Member #: 1291
Suffolk / Birmingham
Its very easy to do if you have a press and make a tool up to support the piston adequately
JT
Member #: 637
Hertfordshire
Might just get the machine shop to do it when I take my block, crank and rods to them.
My build thread..
PhilR
Member #: 10034
Birmingham
Are you planning to take the pistons home between removing and refitting? You have a chance to balance them , or at least juggle the pins around to get the best balance.
Edited by PhilR on 4th Jul, 2015.
JT
Member #: 637
Hertfordshire
Well I'll see if the guys that are doing the engine work can do it so they'll be able to balance them when they take them off.
I still need to book it all in but I'm planning on using southam mini and metro centre (smmc) as I got them to set my suspension up a few months back and I'm confident in them. Nice bunch of chaps.
My build thread..
