Page: |
Home > Non-Mini Discussion > CNC Conversion | |||||||
16th Jun, 2012 at 11:37:42am
I'm thinking about converting my mill/lathe to CNC control.
Edited by Paul S on 16th Jun, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Jun, 2012 at 11:43:02am
Microw Engineering Ltd - Precision Engineers
16th Jun, 2012 at 11:57:01am
I picked up some american magazines called digital machinist Paul, they did a feature on cnc conversion using mach3 in season 2 mags 1-5 i think (have not unpacked them yet) its really good reading also i think theres a site called my cnc or something theres a fair few threads on conversions again good reading.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
16th Jun, 2012 at 12:00:22pm
Looks like good fun.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
16th Jun, 2012 at 02:01:10pm
Thanks guys.
16th Jun, 2012 at 02:05:01pm
On 16th Jun, 2012 wolfie said:
I picked up some american magazines called digital machinist Paul, they did a feature on cnc conversion using mach3 in season 2 mags 1-5 i think (have not unpacked them yet) its really good reading also i think theres a site called my cnc or something theres a fair few threads on conversions again good reading. There is a wealth of information on the web. Mach 3 is good because it does the work of a controller. It saves considerable expense. Lots of good suppliers as well: http://www.zappautomation.co.uk/ http://www.cnc4you.co.uk/index.php?route=common/home Lots of forums as well. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Jun, 2012 at 03:52:32pm
Backlash is annoying even with elimintators on the machines there is still a small amount of backlash but doult its like the ones we had in college about 6 - 8 mm of moment on the milling machines :( |
16th Jun, 2012 at 05:28:26pm
I should be able to get the backlash down to 0.05mm, that's fine for the sort of stuff that I'll be doing.
1391 Posts Member #: 1686 Post Whore Oxford |
16th Jun, 2012 at 07:47:55pm
Is there a reason why you couldnt machine a coupling to fit the stepper motors directly to where the handles are currently?
OMG Robert that's a big one |
16th Jun, 2012 at 08:07:52pm
Too much backlash. You need to eliminate backlash if you wish to cut a perfect circle with an end mill.
16th Jun, 2012 at 09:08:25pm
Ah, of course. Essentially in this case how much you need to the ballscrew before the machine will move in an axis?
On 16th Jun, 2012 Paul S said:
Too much backlash. You need to eliminate backlash if you wish to cut a perfect circle with an end mill. These ballscrews minimise and can even eliminate backlash. Then you can drive the tables to move the workpiece in a perfect circle. Edited by Sam on 16th Jun, 2012. On 19th Feb, 2011 Miniwilliams said:
720 Posts Member #: 2588 Post Whore Pretoria South Africa |
17th Jun, 2012 at 08:22:12am
A mate of mine is cnc-ing his mini mill. He found a guy in the states that made a conversion kit for his machine.
857 Posts Member #: 1778 Post Whore Northants |
17th Jun, 2012 at 10:57:34am
Yeah, some of the popular mills x2, x3, etc all have cnc conversion kits. Lots of manufacturers rebrand these machines and they are easily available in the UK. You can also buy one that's already been converted by Syil although the support isn't great.
17th Jun, 2012 at 03:29:09pm
Ideal then.
17th Jun, 2012 at 03:48:55pm
That's a few steps further on. For now we are just going to use manual spindle control. Set the speed with the pulleys, turn it on forward and leave it running :)
17th Jun, 2012 at 04:31:33pm
As the old boy says, C11G for the breakout board, kl-5056 for the drivers and nema 23's for the steppers.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
17th Jun, 2012 at 05:49:22pm
good luck with your conversion. i take this sort of thing for granted with where i work. but to have your own small set up at home would be pretty neat.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
17th Jun, 2012 at 06:27:24pm
Have a look at MasterCam and EdgeCam. I used EdgeCam at work, didnt take too long to workout how to use it. The tough part was learning the feeds and speeds that you can use on certain cutters and your specific machine. "So wat we gonna do tonight Brain?"
20th Jun, 2012 at 03:14:11pm
Components for the cross-slide conversion:
20th Jun, 2012 at 09:20:55pm
All looks pretty fun Paul 0.05mm isn't massive amounts :) not like your working to stupid tolarences |
25th Aug, 2012 at 03:27:22pm
I've made a little progress:
Edited by Paul S on 25th Aug, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4890 Posts Member #: 1775 Post Whore Chester |
25th Aug, 2012 at 03:37:37pm
Looks simple yet complicated. I run a supercharger and I don't care the TB is on the wrong side.
6745 Posts Member #: 828 Post Whore uranus |
25th Aug, 2012 at 05:36:46pm
first test is going to be very exciting i reckon ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Aug, 2012 at 05:57:34pm
On 25th Aug, 2012 robert said:
first test is going to be very exciting i reckon ! Do you have body armour? Just in case... On 11th Feb, 2015 robert said:
25th Aug, 2012 at 06:07:01pm
Emergency stop is on order :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
