Home > Show Us Yours! > 1800 16v - build thread
MarkGTT
Member #: 1194
Shropshire.
This will be a new experience for me, firstly its my first round nose, a B plate Mayfair
It will be my first full steel mini, so will require a few replacement panels and no doubt test my welding skills.
And it will also house a new engine, and to my knowledge its not been done before.. or if it has there are very few about. A vauxhall small block 1800 x18xe1 with jenvey itb's.
I bought the mini a few months back and seemed tidy enough.
Ive now got the shell stripped and found a few areas that will need attention.
This had been repaired.. with masking tape lol
And it has a nasty set of over sills. Other than that it seem very good, original and not like a patchwork quilt.
should have it up on a spit in the next day or so and the body work will begin :)
Edited by MarkGTT on 22nd Jun, 2014.
Doesn't look bad at all, you should have the welding done by the end of the weekend.
A friend of mine had an 1800 with jenvy tbs and a worked head +crank and n2o in his vectra, he was pulling 199hp w/o the spray
MarkGTT
Member #: 1194
Shropshire.
*wink* nice
Chalkie
Member #: 9764
Northamptonshire.
SNAP! mines gone here this bad :/
Holey crap!! I've never seen the flitch panel that bad before, and I have seen some bad minis.
Let me save you some money now and sell you the Cooper shell I'm trying to get rid of for £250. *happy* you'd save that in not having to do some of those repairs, as i'm sure that will have been plated up such that the Titanic would have been jelous.
MarkGTT
Member #: 1194
Shropshire.
Sprocket let's hope that's as bad as it gets haha.
Have a few heritage panels to fit, the fitch / a-panel and wing being the biggest!
Also have the outer wings, sills and need a front panel.. Fingers crossed that's it.
MarkGTT
Member #: 1194
Shropshire.
Had a few hours in the garage this afternoon so thought i would tackle the oversills.
As expected the old ones were underneath, The nearside original sill was in a bad way the offside only had a few holes - all the floors and inner sills are solid.
will fit the new sills once the shell has been blasted.
Next on the list is to remove the front end and nearside inner fitch.
408.Luke
Member #: 9909
Tyler, Texas
Is a vauxhall small block like chevy small block v8? I looked at putting in a LS"x" motor in mine but just couldn't see where i would find the room for it unless it was mid engined
-1974 Mini 1000 - BRG Turbo Build Soon to come
-04.5 LLY Duramax - RC/LB - White - Built Trans - EFILive - Dropped 4/6
-2013 TDI Passat - SEL - White - Lowered on Coilovers - Daily Driver
-2003 Silverado SS - 408 Stroker - DP NO2 - Full Suspension ~900hp For Sale
jlay
Member #: 1742
essex
no its only a 4 cyl. not that big an engine but still tight fit
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
MarkGTT
Member #: 1194
Shropshire.
nope sorry to disappoint, vauxhall small block comes in 3 flavours a 1400 a 1600 and an 1800. The big block starts at 1800 and above.
those GM v8's are huge in comparison, like you said rear / mid engine only i guess.
Andy500
Member #: 2443
Cheshire
Looking forward to watching this develop, will it all squeeze under a standard roundnose?
MarkGTT
Member #: 1194
Shropshire.
I hope so mate
Chalkie
Member #: 9764
Northamptonshire.
I hope so mate
8 valve vaxu engine fits under standard round nose fine :) tight but fine
MarkGTT
Member #: 1194
Shropshire.
I know the 1600 16v fits.. It's the 1800 head that could cause me some issues, but I will make it all fit :)
jlay
Member #: 1742
essex
with things running very tight you can get the red top lump in a standard length round nose (just) so im sure you will be fine
MarkGTT
Member #: 1194
Shropshire.
It's not the overall size that concerns me it's the angle of the inlet. Will find out soon enough :)
not sure about the similarity of these vauxhall engines but there was a guy in Glasgow a good few years ago running an old cavalier SRI 1.8 8v in his round nose.
MarkGTT
Member #: 1194
Shropshire.
I think that's a big block - mine has come from a newer Zafira.
kcchan
Member #: 8853
Get some ITBs on there!
MarkGTT
Member #: 1194
Shropshire.
have a look at my last build mate *wink*
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=400501
Edited by MarkGTT on 4th Jun, 2012.
MarkGTT
Member #: 1194
Shropshire.
Bit more body chopping done today. About halfway through taking the nearside fitch and inner wing off, i can save the other side so thats a bonus as its an original panel.
Need some more cutting discs and another spot weld bit..
Seems to be going well at the moment, should be able to book it in for blasting soon.
maccamcvey
Member #: 6673
Worral Sheffield
looking good, are you going for a removable steel front?
MarkGTT
Member #: 1194
Shropshire.
Did think about a removable front.. Not sure I will ba able to get the finish I'm after though if I do.
Would make working on the engine loads easier though!
kcchan
Member #: 8853
Can't wait to see this develop.
Users viewing this thread: none. (+ 4 Guests)   Next ->
