Home > 998cc > Which exhaust are you 998 lads using?
wagon_rider
Member #: 9241
Edinburgh / Dumfries
Hiya - just a simple question
Which back boxes/silencers and exhaust dia's are you lads using on your 998 turbos?
2".
wagon_rider
Member #: 9241
Thanks
dan187
Member #: 6724
Wootton Bassett
play mini 3" but mainly because i was given it. centre pipe section is 2" just the silencer exit is 3"
1275 EFi Turbo
jdisel
Member #: 9515
ireland
Im thinking of going with the same as you dan187, how does it sound, is it very loud.
A job worth doing is a job worth over doing
if its just the back box yes very, if you have the linkpipe box too it is manageable but your ears ring after a motorway session, i ditched both for a twin box maniflow 2"
jdisel
Member #: 9515
ireland
Well my plan was a 2" pipe from the turbo to the backbox, you recon it would be too loud,
I have no experience with any system so do know what to go for, was it a turbo engine you ran it on.
Sorry for the hijack.:)
it was a non turbo 998 then on the 1293 turbo ( my first turbo engine) i would run a single box with turbo its quite suprising how much sound they take from the exhaust, infact i have run with no silencers and a turbo, it was fairly civilised
wagon_rider
Member #: 9241
This was what I really had in mind *wink*
compound turbo's, i thought about that too, reguards the exhaust, there is always next year *wink*
dan187
Member #: 6724
Wootton Bassett
As mentioned, the turbo takes out most of the noise. It is so much quieter than my 1275 N/A which has a 1 3/4 " maniflow system.
Many people have said it is the quietest mini they've heard. The frequency of it is very low so on a motorway cruise you do get a bit of a drone but the exhaust noise is easily dwarfed by the turbo whine and induction noise.
I'd recommend it.
1275 EFi Turbo
jdisel
Member #: 9515
ireland
I might get one so and see how it goes,
Thanks lads.
if you have straight cuts you wont hear much engine anyway *tongue*
Ben H
Member #: 184
Melton Mowbray, Pie Country
I find with turbos the intake noise is almost zero compared to a NA with a large stack or trumpet.
Yet another advantage of a turbo.
http://www.twin-turbo.co.uk
bennyy
Member #: 9037
Doncaster, yorkshire
So to conclude, don't fit a backbox, fit a turbo instead.
Edited by bennyy on 1st Jun, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wagon_rider
Member #: 9241
ha ha ha :)
then beg the mot man for an mot *happy*
