Home > 998cc > 998 120 over pistons
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
are they able to take a hiding?
they seem kinder cheep but i guess there nothing special like forged or billet slippers ..
i plan to use them in a 998 block balanced std crank and rods with a worked 202 head
mattsmadmini
Member #: 9965
Sydney, Australia!
truth be told, not worth the effort, there are so many 998 blocks lying around, 80 or 100 thou OB would be my max, 120 (maybe 100) requires offset boring which costs a bit... its more for the wank factor going that big... its cheaper to just straight bore, some good 80thou pistons can be had from Graham Russel here in Oz, i think he sells them on to K.Dodd... anywho, 80thou would be the way to go, if a piston buggers up and scores the bore, chuck it at the scrappers and pick another 998 block off the pile...
my 2.2c
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
If the pistons are made to the same design as the smaller ones in the range then they should be up to the abuse.
Edit: I assume these are hypatecs or whatever they are called.
Edited by minimole23 on 1st Jun, 2012.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
yeah i suppose it would be better to go 0.080" over and spend the cash saved on balancing or something eles.. it was just a thought 0.120" over with 1098 crank and rods would come out at about 1202cc vs 0.080" witch gives 1166cc hmm
Advantage
Member #: 1450
Near Paris - France
I had the idea once but +120 pistons are 998 items with a bigger crown height than 1098 pistons (more stroke, same block height and same rod length).
Si if you want to fit pistons that are dedicated to 998 on a 1098 crank, be ready to remove 3,5 mm off the top of them ...
Rusty by nature
