Home > How To > DIY mod: diaphragm->piston dump valve
turbo1312
Member #: 64
All you need to do is to make piston and find fuel resistant ring and rubbers that you can fit (note rubber that goes between two parts of valve body is missing). And it works! I did this because my dump valve diaphragm split and I couldn't find new one here in Croatia...
