Page: |
Home > Technical Chat > What actually causes the Flywheel to fret on the tail of the crank? | |||||||
4304 Posts Member #: 1321 Post Whore Wiltshire |
21st Apr, 2012 at 04:46:31pm
I have been inspecting one of my spare cranks recently, I did not remove it from an engine and do not know its history, however it is perfect in every way including the journals which are standard.
21st Apr, 2012 at 05:10:01pm
Dirt between tapers,
I seriously doubt it! |
21st Apr, 2012 at 05:32:18pm
could have spun and friction welded to the crank and then someone managed to pull the fluwheel off, including doing this damage |
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
21st Apr, 2012 at 07:10:03pm
Who you calling an idiot?
21st Apr, 2012 at 07:14:09pm
On 21st Apr, 2012 Chris Dillow said:
Who you calling an idiot? LMFAO I seriously doubt it! |
21st Apr, 2012 at 10:25:27pm
IMO (and this really is just an opinion...) as long as the flywheel is on properly in the first place is thould not fret, I always heat my flywheel and fit it, after lapping it, also I torque to way over 150ft lb, 150 on the torque wrench then a big heave on the breaker bar, probally about 200ft lb...
22nd Apr, 2012 at 07:48:29am
Good point joe, could just be a dogdy clutch change. I have been slightly concerned that the fatigue life of the item may have been reduced, but I suppose a loose clutch assembly is the main clupret.
973 Posts Member #: 3228 Post Whore North of the Netherlands |
22nd Apr, 2012 at 09:16:50am
Maybe a bit of a nupty question, but I searched to find out about this lapping of the crank but couldn't find details.
Dazed and Confused.... |
22nd Apr, 2012 at 09:30:21am
yep thats what I do,
22nd Apr, 2012 at 10:38:10am
Clear, cheers Joe Dazed and Confused.... |
1st Jun, 2012 at 07:21:10pm
Another engine another damaged crank, this time from a 39k automatic.
1st Jun, 2012 at 08:23:58pm
Fuck it, itl be fine to use that.
1st Jun, 2012 at 09:22:39pm
On 1st Jun, 2012 cossierick said:
Fuck it, itl be fine to use that. rick I think the same, but like things to be perfect considering it will be doing mostly 8k circuit work. I think I have OCD! It'll clean up by lapping on the flywheel, but I just don't like the fact somethings not right to make it do it in the first place. Edited by minimole23 on 1st Jun, 2012. On 7th Oct, 2010 5haneJ said:
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
2nd Jun, 2012 at 07:13:02pm
a billet crank will be no different to the above is it is subjected to poor fiting /poor balancing/ poor damping
On 1st Jun, 2012 minimole23 said:
Another engine another damaged crank, this time from a 39k automatic. Bollocks to it I think when the time comes I'll whack a billet one in there, I can't be bothered to keep messing about. ![]() |
2nd Jun, 2012 at 07:26:45pm
yep, in fact Ive heard billets can be worse due to the different material, probably bollocks though.
2nd Jun, 2012 at 08:26:32pm
Perhaps you need one of these? http://www.minifreunde.at/harry/links/flywheel.htm but you may have to have it re bushed at some point as its the bronze that takes the damage, rather than your super duper expensive modified crank. On 26th Oct, 2004 TurboDave16v said:
3589 Posts Member #: 655 Post Whore Northern Ireland |
3rd Jun, 2012 at 02:37:01pm
Would I be right in saying the problem is more common on vertos than old flywheels ?
3rd Jun, 2012 at 04:55:29pm
I never over torque, especially with the steel flgwheels as they have a habit of sticking on.
3rd Jun, 2012 at 06:21:21pm
With experience of fretting of aluminium centrifugal impellors with a parallel bore on steel shafts, it would appear that it is all down to the torsional vibration or rotating balance.
5th Jun, 2012 at 02:01:49pm
On 3rd Jun, 2012 Sprocket said:
With experience of fretting of aluminium centrifugal impellors with a parallel bore on steel shafts, it would appear that it is all down to the torsional vibration or rotating balance. Exactly, which is why I am slightly concerned that whatever dodgy vibrations are there may have reduced the fatigue resistance of the cranks, the damage itself is minimal, just the fact that something undesirable had to cause it. On 7th Oct, 2010 5haneJ said:
6th Jun, 2012 at 10:43:27am
as pointed out above i thought its caused buy a miss match in grinding at the production stage of both flywheel and crank and as a result any vibrations make the two work on each other and more or less weld together.?.? |
Page: |
