Home > Show Us Yours! > the rebuild....
TurboPickle
Member #: 9621
Scotland
Hiya guys, I had been looking on this site for ages while I did my original engine work but as im now signed up I thought I would show you guys what im doing.
Edited by TurboPickle on 15th Oct, 2013.
TurboPickle
Member #: 9621
Scotland
Some more :)
Its looking good, have you worked out what compression ratio it will be running?
TurboPickle
Member #: 9621
Scotland
Yes, compression is around 9:0 to 9:1 and planning on running 10psi with intercooler so should have some nice usable bottom end.
sounds nice and realistic
Craigie-B
Member #: 9468
Wootton Bassett
sounds almost identical to mine :)
Im running a 1310cc with the 10cc omegas, t2 turbo, kent 266 and looking for 10psi
what sort of power are you hoping for? I was hoping to make around 120bhp
should make a nice drivable motor, sounds like what i started off aiming for
TurboPickle
Member #: 9621
Scotland
[quote=Craigie-B,10th Apr, 2012]sounds almost identical to mine :)
Yh the plan is to have a nice drive but with a bit of ooomph when wanted.
mines 1293, 10cc omegas, t2, avonbar phase 2 cam, 10psi and hoping for 120-130bhp. keeping all helical gears aswell so dont really want to be putting out any more than that.
Some goodies to fit :)
TurboPickle
Member #: 9621
Scotland
Some more progress.....
Losing some weight
New o/s, n/s and rear boot floor. o/s wheel arch is also new.
Two repair sections to each side of the rear seat also.
Butt welded everything so theres no overlaps to rust away. Took ages lining everything up just right but worth it.
That gearbox looked close to death!
Good work with the shell, I moaned when restoring mine but looking at pictures of cars with entire floors missing makes mine seem insignificant!
bennyy
Member #: 9037
Doncaster, yorkshire
You have been busy
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
TurboPickle
Member #: 9621
Scotland
Yh gearbox wasnt too pretty.
Its nice to actually get more panels going on the car rather than taking everything off!
What do you guys think of the valance?
Was thinking of maybe putting some more smaller holes on the top row but dont want to make it too holey *happy* lost 0.25kg from it so far.
Did you check that you hadn't put holes where it mounts to the closing panels on the car?
TurboPickle
Member #: 9621
Scotland
Im not going to put the closing panels on. Just the valance.
I know the closing panels help stop mud etc but with the holes hopefully it wont clog up too much.
I'll just wash it out every so often.
moth tester might not like that. they are part of the rear subby mounting body structure. I'll bet it will be floppy without them too
Just noticed your location, where abouts in the shire are you based?
