Home > Help Needed / General Tech Chat > Standard Metro turbo piston to deck height
As per title. What's the distance?
Many thanks
They are flush with the deck.
Are you sure?
The ones we stuck in the van where. How else would you get 9.4:1 with an 11cc dish?
bennyy
Member #: 9037
Doncaster, yorkshire
I thought they were about 10thou?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
I though 10 thou too. I was just checking.
I thought they were 30 thou down.
I thought it was only about 10thou, but it's a long time since I checked. The piston dish is 12cc so if it's more than 10thou or so how do you get 9.4-1 compression ?
yeah I'm wrong... its about 10 thou aparently,
no need for decking then, maybe just get the to flash it nough to get it flat.
Cheers guys :)
I had my standard block skimmed 10 thou and they stuck out the top of the block!
I'll tell you what.
I'll stop scratching my arse and stick my rods and pistons into my spare block and have a measure *wink*
Havent I already told you to do that! *tongue*
we are talking BL and Rover here gents, the fucking things may well range form 1mm down the bore to sticking out of the top, dry build and measure,lol
Lol
From memory they are flush. The maths suggest this too since the dish is 12cc and the ring land is 0.5cc, with a 21.4cc head and gasket volume of 3.8cc is bang on 9.44:1 CR
I'm certain the ones that went in both blocks we used in the van where flush with the deck....
