Page: |
Home > Help Needed / General Tech Chat > Ball bearing type hif44??? | |||||||
14th Mar, 2012 at 07:16:42pm
I need to take a green spring with me to the rolling road on the 23rd. I live fairly close to Somerford do I asked if they can get one - they have gotten everything else I've ever asked.
14th Mar, 2012 at 07:52:25pm
some of the carbs have a ball bearing sleeve thingy between the piston and the chamber. IIRC I run a supercharger and I don't care the TB is on the wrong side.
14th Mar, 2012 at 07:57:46pm
If you dismantle the piston/damper mechanism, you'll see a plastic sleeve with bearings in.
Edited by theoneeyedlizard on 14th Mar, 2012. In the 13's at last!.. Just |
14th Mar, 2012 at 08:36:28pm
Yeah Ive never seen an HIF without the balls either. On 28th Aug, 2011 Kean said:
14th Mar, 2012 at 08:38:00pm
what they said, all the HIF44's ive played with have had them Yes i moved to the darkside |
14th Mar, 2012 at 09:10:48pm
So their in the end of the bit that goes in the hole that screws in the top?!
14th Mar, 2012 at 09:47:21pm
With the damper plunger removed, If you push the piston in to it's full extent you will see a small clip on the the end of the dampers oil chamber thing. (Don't squirt oil in your eye).
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
14th Mar, 2012 at 10:03:57pm
The non-ball bearing type looks like the one on HS carbs... Tiny, flat top screw; ball bearing type is the 'fat' chunky type :) [X] nail here for new monitor |
50 Posts Member #: 7192 Advanced Member bradford |
14th Mar, 2012 at 10:21:53pm
as far as i know, all hif's use the same springs...
ask me tomorrow for discount |
14th Mar, 2012 at 10:30:11pm
of course you can swap the old type onto an HIF... On 28th Aug, 2011 Kean said:
15th Mar, 2012 at 08:04:06am
Very strange - my piston just comes out of the dash pot....
15th Mar, 2012 at 09:07:45am
I certainly have ball bearings!!
15th Mar, 2012 at 09:30:47am
You'll be missing the clip. It doesn't affect the operation on the carb, just keeps stuff together when you remove it.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
15th Mar, 2012 at 09:40:37am
It's in calvers master class in the feb mini mag if you've got that. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
Page: |
