Page: |
Home > Show Us Yours! > Small Bore Build. | |||||||
19th Feb, 2012 at 03:18:07pm
Re Opening my Project page now :) going to build a 998 Edited by Chalkie on 22nd Sep, 2012. |
478 Posts Member #: 9269 Senior Member Rotherham |
19th Feb, 2012 at 03:58:48pm
looking good not much info though Craig
19th Feb, 2012 at 04:00:11pm
Are you going to turbo it Craig
19th Feb, 2012 at 04:00:56pm
. Edited by Chalkie on 20th Apr, 2012. |
19th Feb, 2012 at 04:07:47pm
Yeah I'm just getting uploading photos of work thats been done and being done, still need to weld
19th Feb, 2012 at 04:12:03pm
392 Posts Member #: 5702 Senior Member Cornwall |
19th Feb, 2012 at 11:07:11pm
Are the con rods for circlip pistons? |
20th Feb, 2012 at 07:41:11am
I guess you were told it was rebuilt 2k ago, and now you know it wasn't?
1137 Posts Member #: 1450 Post Whore Near Paris - France |
20th Feb, 2012 at 08:51:13pm
On 20th Feb, 2012 wil_h said:
Is there no chance even a +80 would clean up the bores? If it was me, I'd try and find an A+ 998 rather than spend money on some pistons and rebore. But maybe I am wrong regarding availability of engines vs cost of machining in England. In France, 998 are still rather widely available and machining is fookin' expensive like they give you your parts back machined and gold plated ... Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
20th Feb, 2012 at 10:14:44pm
Con rods are Circlip type yes, the pistons where fitted backwards aswell... and it had all new shells and that in it, But 1275 or new 998 (1060) and turbo it :) Insurance company said i can put turbo in a year after driving the mini on a N/a engine first and it put it up by £150 What is not bad and I work at an engineering company so Machine work isn't really that bad to be fair.
20th Feb, 2012 at 10:16:15pm
Is there no chance even a +80 would clean up the bores? +80 will blow holes in the block its been sleeved on cylinders 3 & 4 :( So new block is in order and picked crank back up off my friend and he said its fine to use :) so that is a bonus |
21st Feb, 2012 at 11:00:29pm
Had a heads up today, I can go see the all the parts that A friend of a Friend has sat in their garage :) All I know there is 3 engines in there so its all good.
22nd Feb, 2012 at 09:15:41am
Sleeved on two cylinders seems odd. Have you a photo of the insido of the block?
22nd Feb, 2012 at 09:47:50am
I can get a picture tonight when im back from college i recon mine is an odd ball it has 2 selved and 2 un selved cylinders but machine shop said just got with a 1293 be more power and alot more useable :) |
22nd Feb, 2012 at 08:11:55pm
Or better yet : K head on a big bore with turbo and injection !
Rusty by nature
22nd Feb, 2012 at 08:42:09pm
Id love to K1100 Head with a turbo! I've seen them on the tube and on this forum they look so much more fun! :) so don't tempt me you lost have already lured me away from a 16 valve K series conversion..
1083 Posts Member #: 8932 Post Whore |
22nd Feb, 2012 at 10:48:11pm
Go 5 port turbo, not a lot more work than an n/a motor... |
23rd Feb, 2012 at 02:36:40pm
could go 5 port unsure at the moment |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
26th Feb, 2012 at 12:24:56pm
Did this have floating pin rods in it with the oil squirty hole on the big end?
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
26th Feb, 2012 at 07:15:59pm
It has the circlip type pistons in it and the con rods are the standard fitments :) he's more than welcome to PM me and ill sort out with him |
26th Feb, 2012 at 07:17:29pm
Right guys Not done anything on the mini at all but will be selling on some of my mini engine parts and also stuck between Supercharger and turbo now :( anyone like to show me a good route to go?
2233 Posts Member #: 9037 Post Whore Doncaster, yorkshire |
26th Feb, 2012 at 07:28:13pm
turbo imo but depends what you want from the engine Edited by bennyy on 26th Feb, 2012. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
26th Feb, 2012 at 07:45:20pm
Want boost and low down power as not high reving power, anyone got an projects and so on with super charges? thanks stephen
Edited by Chalkie on 26th Feb, 2012. |
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
26th Feb, 2012 at 08:05:13pm
I'd go down the turbo route. You quite often hear of people fitting supercharges then going down the turbo route after more power, but never the other way around. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Feb, 2012 at 08:08:40pm
On 26th Feb, 2012 RidingLow said:
Want boost and low down power as not high reving power, anyone got an projects and so on with super charges? thanks stephen Edit: Spelling Yes http://www.turbominis.co.uk/forums/index.p...d=259072&fr=475 On 11th Feb, 2015 robert said:
Page: |
