Home > Show Us Yours! > Malcolm The Mini! Student budget 998 Turbo (eventually)
Foxy10
Member #: 9782
Hello All, I have owned my mini for a couple of years now and the desire for more power has finally set in so i thought i would let you all know what i have been up to :)
im planning on building a 998 turbo engine with a spec that will hopefully look something like this:
-A+ block, crank and rods (purchased)
-Flat top pistons (purchased)
-Garrett T2 turbo from a renault 5 turbo (purchased)
-Mirage stainless manifold (purchased)
-Hif44 (already had just needs a rebuild)
-Metro turbo plenum (purchased)
-S2 cosworth intercooler
-Megajolt
-MPI tank
-Metro turbo fuel regulator
-Standard gearbox (already have) with central pickup and x-pin diff
Probably missed lots off but it gives you an idea. I have never rebuilt an engine on my own before so iv jumped in at the deep end a bit but it should be a good learning exercise. My car is off the road at the moment as im just waiting for some welding to be done on it before i can mot it but it shouldnt be too long before i have it back :) i have missed it lol.
Here are some pictures of the engine stuff
and here is the car that the engine will be going into
which when i bought it looked like this
Thanks for looking :)
Iain
Welcome! Nice project! Btw That's a HIF38 and most definitely not a turbo carb. Will need converting.
Edited by John on 11th Feb, 2012.
Foxy10
Member #: 9782
Oh right :( i was aware that it was an n/a carb but someone told me it was the 44.
Do you think it would be advisable to get rid of that and look out for a 44?
Mike-998
Member #: 9774
Buckinghamshire
Looks good :)
I'm collecting bits for my 998 turbo, which will probably end up being the same spec as you've said, but i've got a cooper head, but i'm at much earlier in the process than you, still collecting parts and have a way to go..
I'll be following this though, as it should help me with my build.
Just out of interest whereabouts are you in the country?
Foxy10
Member #: 9782
im still very early in the process too :) is it the 12g295 that you have? thats what i am looking for (knew id forget something)
i live near winsford in cheshire but go to uni in stafford :)
Don't see why you couldn't convert the HIF38 to turbo spec. May suit the 998 well
Mike-998
Member #: 9774
Buckinghamshire
Ahh, at least you have more bits than me, i only have a T2, the head (which is in bits) and megajolt in the post.
I'm at uni in Hertfordshire, so its a bit too far for me to have a nosey *tongue*
And i got my head off ebay, it had no bids as it looked in horrible condition, but it hasn't turned too bad so far, a good clean has done it good.
in the plenum theres a restrictor plate to make the carb behave correctly under boost, to use the hif 38 you'd have to make another one the correct size. not sure how big that would be though!
Beno174k
Member #: 9548
Manchester
good luck mate
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578
dig-mini
Member #: 9269
Rotherham
Yes good luck it never easy doing something that is not standard, you can't just buy the parts done you have to mod them which can take time and money to get it right.
Craig
Foxy10
Member #: 9782
Cheers everyone
hmm i will have to think about the carb situation a bit more
Cheers :)
very small update
spent tonight cleaning up the block with brake cleaner
not sure if the pictures will do it justice
*wink*
dan187
Member #: 6724
Wootton Bassett
Have a look at my budget 998 build linked below. I did a similar thing. Cost me about £600 for the parts.
1275 EFi Turbo
Foxy10
Member #: 9782
Yeh i have read through your build a few times (again just then), its really quite similar to what i am planning. Very helpful thankyou :)
Foxy10
Member #: 9782
Evening all,
i havent made any real progress apart from buying a hif44 off ebay.
On closer inspection of the turbo i have noticed that the turbine housing has two cracks in it around the actuator valve hole. i have read that some cracks will not affect performance but i was just wondering if anyone would be able to tell be if these are ok or is it scrap? here is the picture:
Thanks
Iain
Most of them do that. It's not a problem.
Foxy10
Member #: 9782
Ahh that's a relief, thanks
Foxy10
Member #: 9782
Just thought i would let you know what i have been up to latey.
Mainly been playing with carbon fibre vinyl.
also bought a new drivers seat, still waiting to find a matching passenger one.
and a new steering wheel (just waiting for the boss to come before i can fit it.)
cheers
Iain
bennyy
Member #: 9037
Doncaster, yorkshire
Looks like a good job you have done, I did my dash and struggled around the curves.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Foxy10
Member #: 9782
cheers pal, yeh it has come out better than i thought
Foxy10
Member #: 9782
Heres a picture of the arches fitted on one side
*happy*
But more importantly i was having a quick play with my manifold kit on a spare head and im a bit worried that i have been mugged off and just been sold a randomly bent bit of pipe. When i placed the main bit onto the flanges, it seems to be too short. Here are some pics:
Anyone have any suggestions?
Thanks
Iain
cut it in half and put some more pipe in the middle.
Foxy10
Member #: 9782
That seems so obvious now you have said it thankyou.
In other news i have managed to buy 3 12g295 heads off ebay for £250! Bit of a bargain as i can sell two and make most of that money back :) Apparently one of them is unskimmed and has the original 28cc chambers but i will measure them to be sure. Going to pick them up on Thursday *happy*
Iain
wez
Member #: 9271
Stoke on Trent
Where did you get that kit from? And how did it set you back?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Foxy10
Member #: 9782
It was £62 off ebay pal :)
haimesyboi
Member #: 5702
Cornwall
What does the rest of the kit consist of? either get a tee section to make the center branch, or add a bit in the middle from one of the bent ends, they look quite long.
Users viewing this thread: none. (+ 3 Guests)   Next ->
