Page: |
Home > FAQ / Knowledge > MOT emissions for the Mini | |||||||
2nd Feb, 2012 at 12:56:19am
There is from time to time some confusion that reigns over MOT emissions tests carried out on Minis. For the most, it is fairly straight forward, but for the few, it can be a nightmare.
Edited by Sprocket on 10th Dec, 2013. On 26th Oct, 2004 TurboDave16v said:
397 Posts Member #: 694 Senior Member Shropshire |
9th Feb, 2013 at 12:07:07pm
I know I am dragging this post form the depths of the archive. I did use the search function |
![]() 293 Posts Member #: 10010 Senior Member Northants |
9th Feb, 2013 at 01:02:22pm
The test is done on whichever is older, the engine or the car, in your case it's the engine. But it is up to you to satisfactorily convince the tested that the engine is out of an 88 car. Obviously if you do not mention to them about the engine it will probably be tested on the cars age due to this being easier to determine. It would be good to bring along documentation linking the engine number to a specific age vehicle if possible. |
9th Feb, 2013 at 02:55:51pm
I suppose the real question is does having an older engine in a supposedly cat equipped car mean you can remove the cat completely ? |
9th Feb, 2013 at 09:30:06pm
Grey area.
On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter.
Page: |
