Page: |
Home > Help Needed / General Tech Chat > Denso Wiring | |||||||
825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
12th Jan, 2012 at 08:11:05pm
Any one got any wiring diagrams how to wire a Denso alternator into the system, and can anyone tell me what each terminal is for, know where to buy the 3 pin plug other than, Demon Tweeks, because 18 quid seems a bit expensive and finally any pictures would be welcome.. Thanks Alan
Main Build
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
12th Jan, 2012 at 08:32:03pm
Edited by apbellamy on 12th Jan, 2012. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
3249 Posts Member #: 1194 Post Whore Shropshire. |
12th Jan, 2012 at 08:34:25pm
Andy beat me to it. Same alternator as mine :) |
684 Posts Member #: 9590 Post Whore Derby |
12th Jan, 2012 at 08:39:13pm
Im sure ive seen a topic on these denso alternators before on here. might be worth a look.
Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
12th Jan, 2012 at 08:44:54pm
Seems to be combination of type 4, and type 7, because of the big terminal on the side with the capital B at side of it, dose this terminal go to the solenoid / battery Main Build
12th Jan, 2012 at 08:46:59pm
yep the big M6 B tag is the charge output ot the battery.
12th Jan, 2012 at 08:50:02pm
Mine is 3 pin, the photo is a bit blured, did put it in the search, but came up with nothing
On 12th Jan, 2012 mw3 said:
Im sure ive seen a topic on these denso alternators before on here. might be worth a look. I got the three pin plug and alternator from maynard, i found these on ebay and rang them directly and it was 10 quid for the plug. You dont need the plug you can use a narrow push on female blade connector. It looks like your plug has only got two pins in it? This is easy if so, the middle pin in the plug body goes to a switched ignition supply, the outer one goes to the ignition warning light (i dont use this one, as my digidash brings up the lamp on low voltage). If your plug has 3 pins find out which outer pin goes to the warning light by trail and error. Ive left the other disconnected. Connect the big stud to the starter motor live feed with some 6mm sq cable and connect it with yellow crimps. Heres the only picture ive got of mine Main Build
12th Jan, 2012 at 08:57:16pm
Thanks all thats magic, think I can sort it now.. Alan Main Build
12th Jan, 2012 at 09:09:54pm
Ive typed Maynard into the search on ebay but not comming up with anything got any more info on that.. Main Build
12th Jan, 2012 at 09:19:41pm
www.maynardltd.co.uk
Matt W
12th Jan, 2012 at 09:22:30pm
Thanks Matt, will do.. Main Build
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
12th Jan, 2012 at 09:30:31pm
Just search for Alternator on here and lots of info will come up.
13th Jan, 2012 at 08:42:30am
I've used 25mm cable from the starter to the alternate. is that too big? On 11th Feb, 2015 robert said:
478 Posts Member #: 9269 Senior Member Rotherham |
15th Jan, 2012 at 09:25:07pm
thats good for 100 amp
Craig
Page: |
