| Home > 998cc > Alternative Pistons For A 1098 Overbore | |||||||
![]() 324 Posts Member #: 9441 Senior Member South Devon |
11th Jan, 2012 at 11:58:29pm
I've got an engine that's with a friend in Wales at the moment that's been fitted with 67.95MM Hillman Imp pistons pushing the engine to 1214CC but as of yet I don't know what condition they're in or if they're useable. I've been looking for other pistons and thought I'd stuck lucky with Mini Sport AU's +120tho 998 ones but it seems that the gudgeon pin on a 1098 piston is high than on a 998 and fitting 998 pistons would cause them to protrude from the block.
12th Jan, 2012 at 12:56:42am
Change the block? Or liner it? I run a supercharger and I don't care the TB is on the wrong side.
12th Jan, 2012 at 08:12:48am
i thought the only difference in the block between 998 & 1098 was the crank? On 11th Feb, 2015 robert said:
12th Jan, 2012 at 08:23:42am
It is. Rods and crank are different. If something is worth doing, it's worth doing half of. |
12th Jan, 2012 at 08:24:06am
and pistons obviously
12th Jan, 2012 at 09:50:24am
You are correct, all a-series engines use the same length rods with different pin heights to compensate for the change in stroke. The only the 970 used different length rods
12th Jan, 2012 at 10:09:30am
Ah appears one is wrong. I thought the 1100's used different rods. Live & Learn If something is worth doing, it's worth doing half of. |
12th Jan, 2012 at 12:21:35pm
I think that to use the imp pistons the block has to be decked a fair bit even on an 1100 so you may be stuck with them...
12th Jan, 2012 at 06:19:09pm
http://www.swiftune.com/Product/459/omega-...a-flat-top.aspx On 13th Jul, 2012 Ben H said:
12th Jan, 2012 at 06:51:38pm
Thanks Joe C, I knew about Reg Patten anyway as my mate who's restoring an Imp put me onto them. I was more looking to see if anyone knew of any other models of pistons that where around the same size as the Imp ones.
