Page: |
Home > A-Series EFI / Injection > Efi Trials - will I damage a new engine? | |||||||
114 Posts Member #: 9645 Advanced Member South Wales |
4th Jan, 2012 at 02:47:02pm
The 998 engine I have needs a complete rebuild for which I have most of the parts now.
Edited by minivan63 on 4th Jan, 2012. |
4th Jan, 2012 at 02:52:48pm
No problem, it will only take a couple of hours on the road to get the tune close.
4th Jan, 2012 at 03:08:29pm
Thanks Paul that's reassuring to hear.
4th Jan, 2012 at 03:12:09pm
There's only one trial that you need to go through and that's the MS3 one. We were running near optimum after less than one hour on the road.
4th Jan, 2012 at 03:15:01pm
This is the first start of the Mig on the MS3 and new engine:
4th Jan, 2012 at 03:22:23pm
That was the bit I was worried about after getting it to start up - running up to 2000rpm to bed in the cam. Although I guess there is no load on engine at this stage so could get away with less than perfect fuelling |
4th Jan, 2012 at 04:12:25pm
As Paul says, I wouldn't worry too much about individual settings (msqs) or the difference between MS2 (siamese) or MS3, they both achieve the same thing in different ways.
4th Jan, 2012 at 04:33:14pm
On 4th Jan, 2012 Rod S said:
So long as you start with symettrical (or near symettrical) injection timing and a reqd fuel value that is about right, you won't harm the engine. Not an option on the MS3, just one injection timing figure to consider, in fact, the only value to adjust manually to set up the fueling. A laptop running VE Analyse Live feature of Tuner Studio will make all the VE table adjustments automatically, based on one of the O2 sensor outputs. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Jan, 2012 at 04:56:27pm
So long as you start with symettrical (or near symettrical) injection timing and a reqd fuel value that is about right, you won't harm the engine. Not an option on the MS3, just one injection timing figure to consider, in fact, the only value to adjust manually to set up the fueling. A laptop running VE Analyse Live feature of Tuner Studio will make all the VE table adjustments automatically, based on one of the O2 sensor outputs. Even easier then ! But I didn't think 20 minutes was too bad for my first attempt on an MS2 :) I still think getting to understand all the settings first helps though, as going into it with limited knowledge/experience can lead to frustration, as I found with the AE settings. Schrödinger's cat - so which one am I ??? |
4th Jan, 2012 at 05:15:17pm
Yes, very important to understand exactly what all the settings mean, even if you use an established .msq. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Jan, 2012 at 09:40:03pm
Thanks for the replies
Page: |
