Page: |
Home > A-Series EFI / Injection > Can you map the fuelling against IAT on MS1? | |||||||
23rd Nov, 2011 at 09:15:25am
Just a thought. I think that some of the inconsistancy in my fuelling is owing to differing air temperatures. When I come to work in the moring (7am) fuelling is great, when on the way home (15:30) it's always rich.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
23rd Nov, 2011 at 09:43:55am
IAT is a fundamental part of the fuelling equation.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
23rd Nov, 2011 at 09:44:30am
Should be under MAT Correction on the Extended menu Wil.
Edited by Carl S on 23rd Nov, 2011. |
23rd Nov, 2011 at 09:53:10am
On 23rd Nov, 2011 Carl S said:
Should be under MAT Correction on the Extended menu Wil. Edit - I do use MS2 however, MS1 sounds like it may be different according to Rod. I stand corrected, I've never seen that menu before, I just reset the calibration for my particular sensor and it appears to work fine. Though as Carl says, the trimming may only be avaialble on MS2. Schrödinger's cat - so which one am I ??? |
23rd Nov, 2011 at 09:57:07am
The warmup curve is set so that there is no correction from 60 degrees. So no enrichemnent in normal running.
23rd Nov, 2011 at 10:14:26am
I just set up a dummy project in TunerStudio for an MS1/Extra and the "Extended" menu doesn't exist.
3591 Posts Member #: 655 Post Whore Northern Ireland |
23rd Nov, 2011 at 11:17:15am
On 23rd Nov, 2011 Rod S said:
IAT is a fundamental part of the fuelling equation. Oddly it's mostly MS users that push this. Yes it can be important if you live in a climate with wildly varying temperatures, and you can get an accurate measurement of air entering the engine In reality the compensations applied over the sort of weather we get here, is really quite small. But where it really does turn into a balls, is heat soak in traffic etc giving plain wrong readings about the air temp. Then it really does mess things up. And then on boost...in theory as air gets hotter you would reduce fuel. Perhaps up to about 40degC I'd agree with that. But no way in hell would I want the ecu to keep pulling fuel as the air gets hotter. I'd want it to get richer with boost as a safety precaution. Hot air is not good ! So in many respects an ambient air temp sensor is much better than one anywhere near the hot engine. But of course from a safety point of view, you want to know how hot the charge air is too especially if you know your IC system isnt up to scratch 9.85 @ 145mph
23rd Nov, 2011 at 11:33:39am
I agree for a normally aspirated engine (the correct units for temperature in the fundamental gas equation are actually degrees Kelvin so the percentage swing isn't much) but on a charged engine where there may be some fairly significant temperature changes (esp. if not intercooled) it is quite important.
Edited by Rod S on 23rd Nov, 2011. Schrödinger's cat - so which one am I ??? |
23rd Nov, 2011 at 03:28:13pm
It's not just an MS thing but a physics thing. If you want to compute the air mass in a speed density setup, you need the temperature. If the measurement is unreliable then it's another issue and you need to correct it either by getting a better physical setup (which may not always be possible) or using a correction for it.
23rd Nov, 2011 at 07:50:29pm
I agree for a normally aspirated engine (the correct units for temperature in the fundamental gas equation are actually degrees Kelvin so the percentage swing isn't much) but on a charged engine where there may be some fairly significant temperature changes (esp. if not intercooled) it is quite important. (edit - typo) Edit 2 Also Stevie, for heat soak, a proper IAT sensor will have an open bulb which will be isolated from the metal body to avoid just this and hence only measure the air temperature, not the surroundings. But as you say, I'm an MS user so I believe in it :) heat soak has nothing to do with that. If you plonk a sensor in a very hot environment, it doesnt matter what temperature the air is, heat soak/radiation from those metal surroundings WILL give false readings. Especially when only small volumes of air are passing. ie at low loads. Ive seen more than a few cars with massive AFR changes at idle and start stop traffic when IAT compensations as per physics would suggest. purely because of heat soak. That's why OEM's, even turbocharged will place their IAT sensor to measure ambient air, and very rarely actual boosted air temp. 9.85 @ 145mph
23rd Nov, 2011 at 09:14:50pm
gotta agree with stevie, im pretty sure i disabled IAT correction on my megasquirt install as i found i could get more consistant fueling without it, i have an open bulb type in the inlet, and the lag on it is incredible, and simply not good enough to be trusted to alter fueling. again, was a post of my datalogs that stevie comented on that prompted this. the IAT would actually go DOWN on boost, this should never happen, and showed that the rubber insulated open bulb sensor was indeed suffering heat soak in low airflow situations. and again i can think of countless turbocharged cars where the IAT sensor is in the pre-turbo ducting. turbo 16v k-series 11.9@118.9 :)
23rd Nov, 2011 at 09:19:49pm
Stevie,
23rd Nov, 2011 at 09:53:01pm
Stevie, I have never seen an OEM measure ambient air temperature. Nearly every single one does. The IAT sensor is often inside the MAF ! And if not there, inside the air filter box. So it's always measuring ambient at that point. The Cossie setup is almost 20 years old, they did things differently back then. And as the air is moving relatively fast, it doesnt geat heated anywhere near what the sensor can see because of heat soak. 9.85 @ 145mph
23rd Nov, 2011 at 09:56:01pm
On 23rd Nov, 2011 evolotion said:
gotta agree with stevie, im pretty sure i disabled IAT correction on my megasquirt install as i found i could get more consistant fueling without it, i have an open bulb type in the inlet, and the lag on it is incredible, and simply not good enough to be trusted to alter fueling. again, was a post of my datalogs that stevie comented on that prompted this. the IAT would actually go DOWN on boost, this should never happen, and showed that the rubber insulated open bulb sensor was indeed suffering heat soak in low airflow situations. and again i can think of countless turbocharged cars where the IAT sensor is in the pre-turbo ducting. An open bulb should respond within a few seconds. The crappy Bosch with the plastic tip has a response time of about 20 seconds, totally and utterly useless. But in a boosted setup, yes even a good one does respond too slow to be relied upon for accurate fuel compensation It would be like having closed loop fuelling with a sensor that tool 2-3 seconds to respond. I'm not saying IAT shouldnt be taken into consideration, but I would only ever allow very small changes, even if it defies the laws of physics. 9.85 @ 145mph
23rd Nov, 2011 at 09:58:05pm
about 2.5 secsreponse on my MPI IAT sensor. On 28th Aug, 2011 Kean said:
23rd Nov, 2011 at 10:33:02pm
To add, the factory MPi has the IAT sensor mounted in the inlet manifold and isolated by a plastic bush. The Rover T series with multipoint injection also has the IAT mounted in one of the inlet runners, again in a plastic bush. The latter also has a fuel temperature sensor in the fuel rail to compensate for fuel density also.
23rd Nov, 2011 at 10:39:52pm
On 23rd Nov, 2011 stevieturbo said:
... The IAT sensor is often inside the MAF ! ... That's a different issue completely. The IAT is not used for the same purposes when using a MAF. In that case, the air mass is directly measured by the MAF. Jean |
24th Nov, 2011 at 07:13:30am
Yes, I too was refering to the speed density programme (which is what MS is usually setup for) rather than MAF as found on some modern cars.
![]() 6748 Posts Member #: 828 Post Whore uranus |
24th Nov, 2011 at 07:59:07am
boost ,temperature ,density fairly constant per design .. , so the engine would be mapped for that design ,so taking all that into account .then the variable is the external air temp.
Edited by robert on 24th Nov, 2011. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Nov, 2011 at 08:09:45am
So this morning I put MAT on the dashboard. It started at 16 and maxed at 20. Not sure what it's reading though on the dial, it said %? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
24th Nov, 2011 at 10:16:34am
The MAT gauge should read Deg C. but that may be due to your dashboard .ini.
24th Nov, 2011 at 11:35:17am
That's what I thought. I'll have another poke around for a dial. I remember before I updated tuner studio it was on there and read what I would expect.
24th Nov, 2011 at 11:40:44am
I've had dials come up as % too.....
Page: |
